Turbo pics inside
Old Jul 3, 2005 | 03:51 PM
Bruce's Avatar
Bruce
Default Turbo pics inside
I take some pics before I am tearing it down. I have post some pics before but they were not complete. For those of you wanna see the complete rear mount turbo C4. The Water to Air intercooler is underneat the car I cannot take any pics without jacking the car up. And the water tank chill by the A/C system is also hidden behind the passenger seat where the old compartment were.
ps. The big long chrome 5" pipe is a home build muffler, it has baffle in side but it is still pretty darn loud. It does sound good though
Old Jul 3, 2005 | 03:53 PM
Bruce's Avatar
Bruce
16 injector setup
Old Jul 5, 2005 | 12:35 AM
DDSLT5's Avatar
DDSLT5
Very interesting. You know your accesory belt is on inside out, right?
Old Jul 5, 2005 | 01:03 AM
BAM92's Avatar
BAM92
It is an early 93, so he has a double sided ribbed belt. They changed in late 93 to the single sided ones like you are thinking.
Old Jul 5, 2005 | 05:01 AM
Bruce's Avatar
Bruce
YES SIR that is correct.
Bruce
Old Jul 5, 2005 | 07:22 AM
Fubar569's Avatar
Fubar569
is this on a vert? if so were you at NYIRP for spring warmup this year? and if so, i remember this car...god damn...sick sick sick...too bad it's coming apart...
Old Jul 5, 2005 | 11:33 AM
Bruce's Avatar
Bruce
Hey Buddy
I remember you. You are got the 95 teal coupe vette with your wife/or girl friend that night?
Bruce
Old Jul 5, 2005 | 11:38 AM
Fubar569's Avatar
Fubar569
i wish i had a 95...
i was the black 1984 crossfire...i had my friend with me that day...we were both blown away with your setup...it is truly saddening to see it come apart...best of luck though!
Old Jul 20, 2005 | 07:35 PM
1985 Corvette's Avatar
1985 Corvette
Geeez, it's projects like these that remind me that anything is possible when it comes to tinkering with a car's performance. Like another in this thread stated, it's a shame that this has to come apart. I can't even contemplate the coolness factor of a homemade turbo setup, it still boggles my mind and the fact that it's a rear mount takes it a step further. I wish I had that kind of setup. Everytime I got out the car I'd walk to the back, crouch down to take a look and just smile.
Old Jul 21, 2005 | 08:11 AM
Bruce's Avatar
Bruce
I decided to keep it and worked out the bugs. Now it run awsome. 3rd gear and 4th gear will push you to the back seat with only 6psi because the the 50s injector is already maxed out. As soon we hook up the the secondary fuel injector. We will set it at 14psi for the street and 24psi for the track.
Old Jul 21, 2005 | 11:05 AM
bigcityvette's Avatar
bigcityvette
how did you run the out line from the turbo to the intake? I'de like to see some pictures!
Old Jul 23, 2005 | 02:42 PM
Bruce's Avatar
Bruce
Here you go. The 3/8 copper line run from the turbo to the intake where the PCV used to be.
Old Jul 23, 2005 | 10:04 PM
bigcityvette
no, the air line comming from the turbo outlet to the throttle body. How'd you get it up there?
Old Jul 23, 2005 | 10:11 PM
Bruce's Avatar
Bruce
if you look closely from the above pics. The 3" red pipe is going down near the header. We have to modify the the a/c box in there to get clearance for the 3' pipe. Also we had to hammer a portion of the pipe to a oval for clearance as well.
Old Jul 24, 2005 | 02:05 AM
bigcityvette
so does the red air line from the turbo to the throttle body run under the car, between the car, or what?
Old Jul 25, 2005 | 09:50 AM
Baldturbofreak's Avatar
Baldturbofreak
it runs in the same manner your stock exhaust did, 3" hot downthe left with the y pipe in front of the oil pan. The return is 3" down the right, a 6x10"Pwr water air intercooler where the pass side cat used to be, and as bruce mentioned a custom a/c box cover with a oval pipe sneaking up along side. Iat's are rarely over 115deg F even on the hottest days.
A custom parallel evaporator (Kind of like a dual evap suburban)setup chills a 3 gallon tank of water for the intercooler.
Old Aug 3, 2005 | 10:52 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Looks like one BAD C4!
To Turbo pics inside
