Mini starter questions...
Old Jul 6, 2005 | 09:01 AM
neat's Avatar
neat
Default Mini starter questions...
I ahve an L98 with longtube headers and I starting to experience heat soak problems with my starter.
Is there a later model, smaller starter out there will work for me? Or do I have to get a mini starter from an aftermarket vendor?
Old Jul 6, 2005 | 09:29 AM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
I would find a starter/alternator rebuild shop in your area and have them rebuild yours. It’ll probably be better than any starter you’ll find at the discount shops.
On a side note, how strict is the safety inspection in UT. I’m thinking about moving there and im not looking forward to the safety/emissions BS.
Old Jul 6, 2005 | 10:02 AM
M.Clough's Avatar
M.Clough
Put on a mini starter! I cant beleave the room you get by removing that 400lb factory starter.
Old Jul 6, 2005 | 10:13 AM
IBEAM700's Avatar
IBEAM700
If we're talking about a 1991 here it came from the factory with a mini starter
Old Jul 6, 2005 | 10:17 AM
scorp508's Avatar
scorp508
Your 91 already has the smaller starter. It is about 1/2 the size compared to an 84-87.
Old Jul 6, 2005 | 10:25 AM
mikey whipreck's Avatar
mikey whipreck
ecklers and mad sell starter heat sheilds. You could always give them a shot.
Old Jul 15, 2005 | 04:11 PM
neat's Avatar
neat
UT is a drag for safety/IM. Its' also a drag if you're not an active member of the LDS church.
S my 1991 allready has the small stater (!). Holy crap, that thing is huge.
I guess I'll look inot a mini starter from Summit or something. Thanks guys!
Old Jul 15, 2005 | 04:46 PM
Red Tornado's Avatar
Red Tornado
A big help once you put the new started in is to buy a DEI heat wrap for it. Your local A&A, Autozone, etc. should carry it. Without protection, headers will burn up a starter.
Old Jul 15, 2005 | 07:11 PM
darkman5001's Avatar
darkman5001
Are your headers coated jet hot inside and outside? My headers run VERY cool, and would not be worried about frying starter. My factory starter went bad, so I just bought a Summit mini starter and also bought the wrap for the starter just to be safe. I bought the starter to fit my flexplate and all. However the mounting block for it did not quite clear the oil pan's rear right corner. I had to grind it down a bit to get it to fit, but it works great. I hope that helps a little.
To Mini starter questions...
