Hey guys, my car has 82,000mi on it, i am considering synthetic but im afriad of leaking oil, its not leaking now but what do you guys think i should go with? Thanks
Like others have said, synthetic won't cause leaks. It might find some. I didn't have any problem. Why change unless the car specifically calls for it? Going to extend the oil change interval? I don't fear leaks, I fear spending $20 extra 4x per year for something I don't have to. I used synthetic in my cars for a while. I am not comfortable with exending the oil change interval which in my mind is the main benefit of using synthetic in a typical driver. Now it's just good quality dino oil, 3 mo, 3k miles for me. Old habbits die hard.
The benefits of synthetic revolve around temperture stability and difference in rate of wear.
The cost difference is negligable these days - It's less than a tank of gas.
I use it. I use it in everything. Lawnmower, pressure washer, truck, honda, and the vette. After taking apart a few motors, I was shocked at how well the detergents actually work. Here's a shot of the underside of the LT1. It's got 60,000 miles and is 13 years old (I had the pan off to change out the front timing cover seals and weld the water pump drive hole shut.)
Here's a shot with the intake off (chasing down an oil leak):
Go for the synthetic. My preference is Shell 5W30 but it is hard to find, so I usually end up with Mobil 1
1.Synthetics lubricate better, minimizing wear
2.Synthetics can handle a lot hotter temperatures than dino oil can.
3.The detergent packages are far superior (since they are built for extended drain) keeping more combustion by products in suspension to be removed by the filter. This leaves you engine much cleaner, minimizing wear.
Most of us don't even consider the extended drain aspects
What's the extended drain porperty? Just curious, I use Mobil 1 in everything I ahve.
Definitely go with synthetic oil. As stated, if a leak is found, switch back. If no leaks develop, you cannot have done anything better for your engine if you tried. I prefer Royal Purple, but everyone has their own preference. Most people on the Forum use either Mobil 1, Valvoline or Royal Purple.
Go with Mobil 1. However, I would closely monitor oil consumption. Synthetic oil has a 'detergent-like' quality and may clean out old oil deposits that are actually helping to seal your piston ring to cylinder bore contact. It also has a more uniform molecular structure and lacks much of the impurities found in conventional oil. This allows it to adhere to smooth metal surfaces better, but, in turn, makes synthetic oil's consistancy much thinner without changing its rated Grade or Weight. These factors make it prone to passing through the gaps or clearances within an engine created by years/miles of normal use with conventional oil. A well maintained, never abused engine may or may not like the slippery synthetic.
I've used Quaker State dino oil in all my vehicles and change the oil every 2000 miles. When I tore down the upper end of my Ford truck at 90,000 miles to replace head gaskets, you could still see the crosshatch on the cylinder walls.
