fuel pump relay?
Old Jul 19, 2005 | 12:17 PM
AAB92LT1's Avatar
AAB92LT1
Default fuel pump relay?
Where is the fuel pump relay on a 92 lt1? Thanks.
Old Jul 30, 2005 | 05:41 PM
Joshman3382's Avatar
Joshman3382
6th Gear
It is under the right hand side of the dash. You will have to remove the lower trim panel under the air vents. Then there are 5 relays under the black cap. The fuel pump relay is the center relay of the row with three relays
