Thoughts on polyurethane bushings
Old Jul 22, 2005 | 08:11 PM
hogs29's Avatar
hogs29
Default Thoughts on polyurethane bushings
I've got an '84 with a tired suspension, and for years I've considered going with Polyurethane bushings in a number of cars I've owned. I've always shyed away because I've heard all the usual reasons not to buy them; too noisey, ride is too rough, not enough performance gain for the money....etc.
Since I can't always trust magazine articles (never sure if they praise them because the commpany advertises in their mag) I decide to ask the real people who have actually bought and used these. What do you think? Would it be worth it, or should I stick with factory replacements?
Big time thanks in advance!
Old Jul 22, 2005 | 08:15 PM
aboatguy's Avatar
aboatguy
This is a common question and I love my polys. So, check outthis thread
Mike
Old Jul 22, 2005 | 08:17 PM
Corvette0096's Avatar
Corvette0096
They work... shocks will firm up your ride to.. Hey, it's a sports car they are going to be firm.
Old Jul 22, 2005 | 08:55 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I'm not impressed with the ES polys. I have em in front, no squeaks, and just put them in back, haven't run it yet with those.
The part I'm not impressed with is the tolerances. The fitment doesn't make any damn sense. It's as if they paid no attention to the sleeve lengths, and it's a crapshoot whether it's rotating on the ID, or the OD, or on the sidesof the bushing. If the bushing is to wide to allow the sleeve to be clamped in place from both ends, then what locates the pivot??? Good idea, poor execution.
Old Jul 22, 2005 | 09:27 PM
goldeneye_vet's Avatar
goldeneye_vet
Love em'. I did the full package of all suspension parts and poly bushings. What an improvement and I'd do it again. Ride is firm and lets face it this isn't your daddy's cadillac!
Old Jul 22, 2005 | 09:51 PM
tigmaned's Avatar
tigmaned
specially your 1984, chevrolet was make a whole new desgin with your first C4, and it impressed alot of the car mags in it day. but yes some whine about the hard ride not knowing its a sports car i guess?????????? heck even 20 years later there still pretty impressive ride and cars.
greatest thing about the polys bushing the will last alot longer then rubber before the deform, so things stay in alignment longer too. i am going to do them soon!! i am even thinking about going with red ones, think it mite look cool since my vette is black.
Old Jul 22, 2005 | 10:42 PM
skeet's Avatar
skeet
I believe that GM uses a harder rubber in their high performance 30mm bars. In any case, there is so little rubber between the bushing bracket and the bar with the 30mm bars that there seems like there would not be a lot of movement anyway. With the smaller 26 and 24mm bars there is a lot more rubber between the bracket and the bar. This is the small set-up (30mm front and 26mm rear and factory rubber)that GM raced their challenge cars and used on their Z07 and Z51 cars. If a 32mm front bar was better than a 30mm bar then GM would have used that.
Old Jul 22, 2005 | 10:59 PM
hogs29's Avatar
hogs29
Thanks for all the answers! And thanks to Mike for the link. I searched for "polyurethane bushings" not "poly". Guess I should have though of that.
Anywho, this now brings about a whole new question. How do I detirmine what size sway bar I have? Tell me it's as easy as measuring it with calipers. That seems logical, but it also seems too easy!
Old Jul 22, 2005 | 11:39 PM
Thrak's Avatar
Thrak
Sorry, I could spell polyurethane after a few beers...
Old Jul 22, 2005 | 11:56 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Seems like alot of people around here use the Energy Suspension (ES) bushings. Has anyone tried any other manufacturer's products, like Suspension Techniques?
Just curious.
Old Jul 23, 2005 | 12:20 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'm not entirely sure they even offer the red ones for the C4 Vette. The black ones are graphite impregnated though and this is better for preventing squeaks. I've had rear ones in for about a year now with no problems. I've got them for the front now too, just need to install them. I didn't find the ride to be substantially different, but it sure feels better.
Old Jul 23, 2005 | 12:33 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Bingo!
They do sell the red ones for at least the sway bars I know. Here is the catch, the red ones are not graphite impregnated. The black ones, as CorvetteKidNC, are. Ask the packages I sent back to Summit how I know...
This fact from the guys at suspension.com
Old Jul 23, 2005 | 01:18 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I'm now in the process of installing ES polygraphite sway bar bushings on the Vette; the front is in but not tested and the rear is to be done soon.
If the Vette responds to the ES swaybar bushings as did the IROC cornering will be greatly improved.
I might install them on the shocks too but will not do any other bushings with the ES.
The fitment of the ES busings I just installed on the front sway bar was right on the money and their tech support was available on the first call and very knowledgable & helpful.
If you want the polygraphite (black) bushings specify the P/N with a "G" suffix.
To Thoughts on polyurethane bushings
