Fan problem origin found...finally
Old Jul 25, 2005 | 07:47 AM
Roscoe's 85's Avatar
Roscoe's 85
Default Fan problem origin found...finally
I just wanted to let everyone know what I found out on my 94 fan problem. The check engine light would come on several seconds after I start the car. At the same time the fans would come on. I tried several times to check the codes by jumping the 4/12 pins but didn't get any codes. I checked a few sensors ( coolant temp, ac system) as well as the relays themselves and still couldn't figure it out. Luckily my employer decided to buy this Snap On vehicle diagnostic unit that adapts to EVERYTHING. Within 2 minutes with the diagnostic scanner running several tests it determined my knocksensors were bad. Crazy but true. Not sure why they failed or even how. I was suprised I didn't get a code with the on board check. Just wanted everyone to know in case they have a similar issue.
Old Jul 25, 2005 | 10:14 AM
VAHROOM's Avatar
VAHROOM
Default Thanks for posting that.
Glad you found it. Thanks for the information. It will probably help some one else in the future.
Old Jul 25, 2005 | 11:11 AM
WEH 2000C5's Avatar
WEH 2000C5
I"m easily confused. There is somehow a link from from the inop Knock sensors to the fan problem? Please unconfuse my tired old mind.
Old Jul 25, 2005 | 11:45 AM
GlennS87's Avatar
GlennS87
When the knock sensors failed, the ECM put you in limp home mode. This generally means that spark is retarded, fuel is added and the fans come on. The point is to keep you from blowing up your engine.
To Fan problem origin found...finally
