Air conditioning question?
Old Jul 27, 2005 | 02:02 PM
redgb's Avatar
redgb
Default Air conditioning question?
My 95 LT1 coupe has been running great. About a month ago an air conditioning problem started. The AC seems to stop when I'm accelerating. As soon as I let up on the gas it starts again. Haven't seen any leaks but no pressure testing has been done.
Anyione have an idea?
Old Jul 27, 2005 | 02:36 PM
SunCr's Avatar
SunCr
If it's floored, it's suppose to work that way. If you have a scanner, the a/c request should go from a "Yes" to a "No" at WOT. Signal is from the TPS which should be pegged somewhere above 4 volts. When the PCM gets this voltage, ground is removed from the a/c clutch relay. On lesser vehicles, you can usually feel the a/c kick out.
Old Jul 27, 2005 | 03:53 PM
redgb's Avatar
redgb
This is happening even when i'm not at WOT. Any other ideas?
Old Jul 27, 2005 | 03:57 PM
brookman's Avatar
brookman
When it comes back is it a rush of hot or a rush of cold?
Old Jul 27, 2005 | 03:59 PM
redgb's Avatar
redgb
When it comes back it supplies cold air. Temp is not the problem and I'm not sure I would call it a rush back. More like normal startup.
Old Jul 27, 2005 | 04:54 PM
brookman's Avatar
brookman
I wasn't clear enough with the question - Does the air go away? or does it just get warm?
Old Jul 28, 2005 | 07:17 AM
redgb's Avatar
redgb
The air goes away it seems in stages. By that I mean a little throttle seems to decrease the air slightly. Greater acceration stops the air more until it stops completely. Then let up on the gas and the cold air starts to flow again.
Old Jul 28, 2005 | 07:18 AM
redgb's Avatar
redgb
Got the pm from SunCr. Thanks I will try to accomplish your troubleshooting.
Old Jul 28, 2005 | 10:23 AM
brookman's Avatar
brookman
I am guessing he told you to look at the vacuum source/hoses . tell us what you find.
Old Jul 28, 2005 | 10:44 AM
Roscoe's 85's Avatar
Roscoe's 85
It doesn't really sound like this since it goes out in stages but when a vehicle accelerates the compressor rpm of course increases. The compressor could be cutting out due to high head pressure (ac charge to high) or low suction pressure (if the ac charge is to low). If it is humid the evap core may be freezing (another sign of a low charge) which reduces air flow and cooling. Just a thought.
Old Jul 28, 2005 | 11:45 AM
SunCr's Avatar
SunCr
High head pressure on a '90 or up should shut it down until power is removed from the control unit; ie, you'll need to disconnect and reconnect the battery to get it running again. This sounds more and more like a loose connection at the low pressure switch if only because I had that problem with my truck and another member had it with his '90. Jumpering the switch harness and taking it for a drive would be the easiest way to confirm or rule it out.
Old Jul 28, 2005 | 11:57 AM
SunCr's Avatar
SunCr
Just remembered the vacuum tank - thanks brookman! - that's another thing to check - lines (use the diagram on the radiator, but it should run from the intake plenum), check valve (under the fuel rail or engine cover - left side) and then the tank (left headlight well) to make sure it holds 10 inches of vacuum . . . more coffee, need more coffee!
Old Jul 28, 2005 | 01:19 PM
brookman's Avatar
brookman
If I understand the answer he gave to my second question - It sounds like the air is being diverted away from the vents. If the compressor was cutting out - you would be getting an initial rush of warm(er) air rather than a air pressure change from the vents. It wouldn't be very safe - BUT - you can reach down near the gas pedal and see if you feel cold air when you are on the throttle.
To Air conditioning question?
