Abs Light
Old Jul 27, 2005 | 11:36 PM
pipe's Avatar
pipe
Default Abs Light
My ABS Light is on in my driver info ctr. I cleaned my wheel sensors and no luck. I removed the tray in the compartment behind the drivers seat to find the union block with all the brake lines going into it. Is this the problem? or is it the small black sensor with the wire connector going into it? My car is a 90 coupe Auto THANKS FOR ANY HELP Also how do you remove the black sensor with the wire connector? I don't want to break the holder or the wire connector. PIPE
Old Jul 28, 2005 | 12:11 AM
mswasty's Avatar
mswasty
Cruising
Default Abs
ABS is tough to troubleshoot. I'm working on an ABS/ASR problem with my 1994. I was trying to check all the sensors but didn't find anything. I would start by getting the ABS trouble codes off the EBCM. I believe your car has On-Board diagnostics, so you can get the codes without an ABS scan tool. With the code you'll know where to look to fix the issue.
Good luck
Matt
Old Jul 28, 2005 | 12:22 AM
jfb's Avatar
jfb
Or find a GM dealer with an ABS tester, it excercises the ABS and then reports where the problem is and what to check.
Old Jul 28, 2005 | 12:23 AM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Which light, "service" or "active"?
Old Jul 28, 2005 | 10:41 PM
pipe's Avatar
pipe
The light says service ABS There's a lot of stuff in that rear compartment behind the seat. It's a 90 L98 auto
Old Jul 29, 2005 | 12:20 PM
JCD's Avatar
JCD
In the later models they can be very finnicky about brake fluid level, it has to be full... just FYI.
Old Jul 29, 2005 | 01:09 PM
chevyc4's Avatar
chevyc4
My '94 had the Service ABS light on and the brake fluid turned out to be low.
Old Jul 29, 2005 | 04:49 PM
split-end's Avatar
split-end
I don't know if this applies to your vette problem, but my '89 coupe abs light would come on when I would hit certain types of bumps. The problem was a bad terminal connection for the abs system at a terminal post near the battery. The solution was to clean the connector and arranged the connector so it wouldn't be affected or moved when the car hit any bumps.
Old Aug 1, 2005 | 11:11 PM
pipe's Avatar
pipe
The brake fluid is full. I pulled my wheel sensors out and cleaned them off they had some grease on em. Then reinstalled them and the ABS light stayed on. The driver info center only blinks out #12 three times. Thats only the check code. But no other codes appear. Do I need a special code scanner? pipe
Old Aug 1, 2005 | 11:51 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Hey split-end, where is this terminal connection? My '89's ABS light stays on - maybe it's the same problem. Got any pics?
And pipe, yes there is a special scanner for the ABS system on these cars. It's listed in the GM service manual (I don't have it close to me, or I'd look it up).
Old Aug 2, 2005 | 05:31 AM
split-end's Avatar
split-end
The terminal is behind the battery near the side vents. You can find the terminal by tracing the cable from the abs wheel sensor to this terminal. Look for a threaded bolt with a nut clamping down several wire connectors.
I'm sorry, I don't have any pictures. I sold my '89 and bought a '96 CE.
Old Aug 3, 2005 | 09:25 PM
pipe's Avatar
pipe
Guess i'll try cleaning off the terminal's and see what happenes. THANKS GUYS
To Abs Light
