Water Leak
Old Aug 1, 2005 | 10:58 PM
fosterj3's Avatar
fosterj3
Default Water Leak
I have an '86 Convertible with a terrible water leak. Water is pouring in between the door and the fuse panel, drivers side. Appears to be coming from where the window, front quarter panel and door meet. Does anyone have any ideas on this. Help would be grealy appreciated.
Old Aug 2, 2005 | 02:28 PM
PITONCA's Avatar
PITONCA
Sound like a heater core problem, hose or something in that area. When a heater core goes bad in any car, they normally leak inside the car.
Old Aug 2, 2005 | 02:39 PM
Steel Blue 91's Avatar
Steel Blue 91
Unless you smell the coolant and have it soaking the PS floor, chances are it is not the core but a simple (?) water leak. How is the A pillar weatherstrip?
Old Aug 2, 2005 | 02:42 PM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
check the weather stripping that area.
Old Aug 2, 2005 | 04:42 PM
mikey whipreck's Avatar
mikey whipreck
Here's my method to solving a water leak like that (assuming it's coming from outside that is):
Take the seat out, and pull the carpet back on that side.
Get inside, and have someone outside spray water with a hose around the door jam area, till you see the leak. You'll probably want to put down towels or something on the floor.
Otherwise, just inspect the weatherstripping to see if something is obviously wrong.
Old Aug 2, 2005 | 11:25 PM
PierEagle's Avatar
PierEagle
Wouldn't that be on the passenger side? Fosterj3 sez it's coming in on the driver's side.
Old Aug 3, 2005 | 09:28 PM
fosterj3's Avatar
fosterj3
Sorry I should have mentioned it only leaks when raining. Sorry I left that out
To Water Leak
