have tons of mags roadtests/internet,track data which I have alist of 0-60 and 1/4 mile performance.You would think every year it would have gotten quicker but thats not neccessarily the case.heres what I have for the "standard" C4's(all automatics)
1.92
2.93
3.96
4.95
5.94
6.91
7.90
8.85
9.89
10.88
11.87
12.86
13.84
only tenths might separate cars with the same engine,but a tenth's a tenth.The 90-93 run better than their MAF counterparts,and 85's because of forged internals,looser converter,and not having precats,run better as well,(I know my bone stock 85 was faster than my 87.so,what do you think,myth,or reality?
Well when you are talking about 1/4 mile ETs you must consider the entire drive train.
For any engine with a particular power curve there is one (with some latitude of course) optimum setup. Deviate not very far from that optimum and the ET number will rise.
Also it is possible that an engine with more power, with one drive train setup, will not perform as well in the 1/4 mile as a lower power eninge with the optimum drive train setup.
As always...it's the system.
AND....THE DRIVER! We always leave that out. Just MAYBE someone else is just better at it than you or I!
These cars are all within a stones throw of each other. Tests vary with temp, weather conditions, track and like what was stated, driver. Of the 5 I have owned I have had an 88, 89 and my 90 were dogs out of the factory and my 89 with the 3.07 optioned auto and my 88 with the 4-3 were faster.
Look at Mojo, his MPH show a 50-60 hp difference. Track conditions were probably a difference and the cars themselves were a good part of it too.
My 90 was absolutely pathetic in it's stock form and a race between the 2 I have now, which was the 89 that was fast, it would have been a pretty poor race.
P.S. I gotta get to that track on the East coast, it must be 1,000,000' below sea level.
No two cars are exactly the same...take two C4's that are identical and one may run much quicker than the other..luck of the draw from the factory...
Frank, I admit I get jealous of you guys up north every summer...from May to November our DA's are 3500+ every damn day...sigh...but when it's 20 degrees with the snow blowin and the tracks are closed up north, I'm racing down here and lounging around in shorts and a t-shirt...btw, I actually raced once down here with a +640 DA...it was 3 years ago but woohoo!...lol
If lower is better then I guess that's another good reason to go to hell...
Low is good! cool is good! However, hot is bad! So Hell is not conducive to great ETs!
Here we always have high, I can feel a power increase when I drive down to Denver ! Yesterday I had hot and high! I can't wait to get back near the water!
what I was getting at was(all cars same rearend ratio,bodystyle etc)
1.speed density cars seem to be about .1-.2 better than MAF cars.This is also true with F-bodys which later cars had slighly better #'s
2.85's considering their horspower rating(230)were slightly quicker than later MAF cars,(245)due to the reasons I surmised
will read you a quote from vette mag(june 94)on a roadtest of a 94 ZO7 6spd"Straight line tests netted fairly dissapointing results by its 13.8@105 time.it was down somewhat from other 6spd's we've tested,especially 92's.Wer'e convinced that while on paper power hasnt changed,but 93's dropped slightly with their revised valve timing,94's took a marginal hp hit with sequential injection." This coincides with most 92 roadtests I have which are in the 13.2-13.4 range.Of course conditons,drivers etc werent the same,and theirs gonna be ringers and theirs gonna be dogs for whatever production tolerance reasons.Also,besides fuel metering,chevy changed certain things which may affect a cars acceleration like torque converter stall,curbweight,tire size,etc,while the power ratings were the same.
