Cylinder Head Plug
Old Aug 12, 2005 | 12:42 AM
skelly1's Avatar
skelly1
Extend the wire and put it on the other side. It ain't gonna make any difference to the gauge.
Old Aug 12, 2005 | 12:44 AM
R23HTC's Avatar
R23HTC
Thanks! That's exactly what I'll do.
Old Aug 12, 2005 | 07:18 AM
STL94LT1's Avatar
STL94LT1
Originally Posted by R94 LT 1
Okay, so you're saying I can cut the wire, extended it to the other side, and it'll still work fine? If that's the case, then that's exactly what I'll end up doing.
Works fine on my car.
Old Aug 12, 2005 | 08:44 AM
R23HTC's Avatar
R23HTC
You don't have any idea how much stress you just relieved! (then again, if you had to do it already, maybe ya do!)
Old Aug 12, 2005 | 09:33 AM
LT4POWR's Avatar
LT4POWR
Have you checked the coolant lines (and holes) that run from head to head?
Old Aug 12, 2005 | 01:39 PM
R23HTC's Avatar
R23HTC
To make sure they are on the right end..........yes.
Old Aug 12, 2005 | 03:55 PM
LT4POWR's Avatar
LT4POWR
How'd you manage that I figured that you put the heads on the wrong side of the motor, and that's why the ECT sensor was plugged/unplugged on the wrong side. That would put the rear coolant openings in the front.
