Cylinder Head Plug
Old Aug 11, 2005 | 11:38 AM
R23HTC's Avatar
R23HTC
Default Cylinder Head Plug
Ran into my first problem with my new cylinder heads today. There's a plug in the passengers side where my cylinder head temp sensor goes! It's a square head and I have no clue as to what size it might be and I don't have any square head tools. Any help with the size would be GREATLY appreciated. I don't want to be buying tools trail and error. I was hoping it would be 3/8 like a socket wrench adaptor, but it doesn't appear to be and 1/4 is to small.
Old Aug 11, 2005 | 11:49 AM
R23HTC's Avatar
R23HTC
Well I figured out part of the problem. The drivers side is missing a plug. Boy I'm glad I caught that before I start dumping anti-freeze. Now all I have to figure out is the size of that square? I think I'm going crazy!
Old Aug 11, 2005 | 11:55 AM
CFI-EFI's Avatar
CFI-EFI
There is a good chance it is 3/8". If so, the end of your breaker bar should fit.
RACE ON!!!
Old Aug 11, 2005 | 12:01 PM
Bob CTS's Avatar
Bob CTS
a 3/8 extension on a ratchet should work
Old Aug 11, 2005 | 12:47 PM
R23HTC's Avatar
R23HTC
I already stated 3/8 wasn't going to work. I've found out it's 5/16, now all I have to do is find the tool.
Old Aug 11, 2005 | 01:07 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
You are correct on the size, I didn't want to mess around looking for something I could use so I took my small propane bottle torch and heated the area around the plug and then put a pair of vise grips on the plug and it came out easily. Didn't even scratch the head.
Old Aug 11, 2005 | 01:15 PM
R23HTC's Avatar
R23HTC
This plug is in so far there isn't anything to grab on to.
Old Aug 11, 2005 | 01:18 PM
cv67's Avatar
cv67
St. Jude Donor '05
Is it an allen head shaped plug?
Old Aug 11, 2005 | 02:12 PM
dock351's Avatar
dock351
St. Jude Donor '06
i think i ran into exactly the same problem. A friend of mine, a mechanic, came over, looked at it, went back to his garage and a little later came back with a 5/16 square headed tool. I think he had ground down a 3/8 " to fit. came out like a charm.
Old Aug 11, 2005 | 04:38 PM
Vetracr's Avatar
Vetracr
Default Same Problem
I just ran into the same problem on the 93 I bought. I tried to remove the driver side plug to put in a fan temperature switch. I bought 5/16" hardened keyway stock, cut off an inch and inserted it into a 5/16" ratchet. The heads are still on the car. The plug was in so tight it would not come out even with a 1/2" breaker bar. It rounded the corners on the hardedned keyway and the plug square is now a parallelogram. I wound up buying a temperature switch you plug into the radiator hose. I hope you have better luck.
Larry
Old Aug 11, 2005 | 04:41 PM
rrubel's Avatar
rrubel
I happened to have a hex key that fit closely enough and was able to use it to remove that plug. Mine wasn't in very tight, though.
[RICHR]
Old Aug 11, 2005 | 04:50 PM
R23HTC's Avatar
R23HTC
Larry
No I'm not having any better luck. I made a tool that fit in there and broke it off inside it. I'm trying to find the proper tool, but that isn't working either.
Old Aug 11, 2005 | 05:07 PM
GS345's Avatar
GS345
St. Jude Donor '11
I had the same problem on my GS. I looked through my tool box and found a square shank screwdriver, cut off the end. Worked wonderfully
jeff
Old Aug 11, 2005 | 06:17 PM
R23HTC's Avatar
R23HTC
jeff
I have a feeling this ones in a little to tight for that. I took a 3/8 inch extension and grinded it down to the proper size. It broke off inside of it. Took me 2 hours to get it out.
Old Aug 11, 2005 | 06:29 PM
ittlfly's Avatar
ittlfly
You didn't say if the heads are on the engine. If not, run it down to a machine shop. It probably take longer to drive there than take the friggen plug out.
Old Aug 11, 2005 | 06:33 PM
R23HTC's Avatar
R23HTC
Yeah they are on. If they weren't I'm sure I could figure it out. I put them on, got them all torqued down, the intakes on, and I'm putting all the sensors back in and I'm like WTH! That's when I found out it's a good thing I noticed as there was no plug on the drivers side. Sure would have been a big surprise to watch all my new coolant come pouring out.
Old Aug 11, 2005 | 06:58 PM
VenkmanP's Avatar
VenkmanP
It's a pipe plug, and what you need is a pipe plug socket.
Such as:
http://buy1.snapon.com/catalog/item....8&group_ID=259
I'd expect NAPA to carry something like this.
To Cylinder Head Plug
Old Aug 11, 2005 | 09:00 PM
STL94LT1's Avatar
STL94LT1
Same thing happened when I changed heads. I just wired/installed the temp sensor on the driver's side.
Old Aug 12, 2005 | 12:26 AM
R23HTC's Avatar
R23HTC
Such as:
I would too, but there was only one parts store around here that even had a stock number for it and they are on back order. No one else could even get one.
And yeah, that Snap-On tool is what I need.
Old Aug 12, 2005 | 12:27 AM
R23HTC's Avatar
R23HTC
Okay, so you're saying I can cut the wire, extended it to the other side, and it'll still work fine? If that's the case, then that's exactly what I'll end up doing.
