alt diode causes erratic idle
If you guys want to understand what is going on with that AC voltage, take a look at this page. I can't link you directly to the page so you will have to follow this.
- http://www.autoshop101.com/
- Click "Technical Articles" on the left
- Click #8 Toyota Charging Systems
- Scroll down to Page 18 of the pdf file
I know this is about Toyotas, but many of the systems are very similar in function.
An oscilloscope is just a graphic voltmeter.
One other thing that your other web page doesn't mention. One or two shorted diodes will drain a battery down in one or two days. It will show a charge of 14 volts with a DC meter and the auto parts tester will say it is a good Alternator.
