Digital Climate Control FLASHING
Old Aug 24, 2005 | 09:14 AM
JUSBAD's Avatar
JUSBAD
Default Digital Climate Control FLASHING
My A/C has been nice and cool, but the other day it went warm all of a sudden and I noticed the light under the vent control (AUTO, vent, defrost) was flashing, and it didn't matter which control it was set to.
It stopped flashing after a few minutes but A/C never got cold again.
Is this a sign that the freon needs added or what???
Old Aug 24, 2005 | 10:01 AM
1991Z07's Avatar
1991Z07
You REALLY need to get a shop manual....
I can't scan the pages, but the diagnostics are this:
If a system fault is detected, the LED indicator above the Mode button will flash at a rate of 60 times per minute (1 second intervals...who wrote this book?)
1) Push & Hold the fan Up arrow and Down arrow at the same time (about 5 seconds)
2) The LCD will show 00 (zero zero).
3) Push "Auto Fan" and the LCD will show the fault code stored.
00 - No Faults
01 - Temperature Door Motor Circuit Fault
02 - Temperature Door Motor Circuit Fault
03 - Ambient Sensor Open
04 - Ambient Sensor Short
05 - In-vehicle temperature Sensor Open
06 - In-vehicle temperature Sensor Short
07 - Solar Load sensor open
08 - Solar Load Sensor Short
09 - Low Freon Detected
10 - UART Failure
There are other things to diagnose when in this mode, but I don't have the time to type it all out.
Hope it helps...
