engine light O2 sensor
Old Aug 26, 2005 | 11:19 AM
Impala Balko's Avatar
Impala Balko
Default engine light O2 sensor
I read the check engine light code and it is two things.
1.) I had a stored code Left (bank 2) O2 sensor then the
2.)current code is a (Bank 1) Right O2 sensor Heater circuit.
The readings were around 450 when they should have been around 20-38. O2 sensor on the right bank. By the readings i am getting from the reader it seems like it isnt even plugged in. Where are these O2 sensors and is there a way to test them to see if they are any good. How hard are they to get at and replace. I just recently had a clutch done which is the reason why i think the O2 might have been left unplugged or not plugged in all the way. because i know the car was moved around witout the exhaust on so that would explain the stored code and the light has been on since i had the clutch done.
Old Aug 26, 2005 | 11:33 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
I had to go to your profile for the year of your car
If it is a 94 then I believe you are right The O2 sensors are in the exhaust up near the engine You can possibly get to them from above but much easier from below Very obvious they are the only things screwed into the exhaust with wires coming out You may want to pull them and if they look bad (black buildup, holes clogged) replace them I have never had much luck cleaning them
Old Aug 26, 2005 | 12:26 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
If you do replace, go with Denso or AC/Delco.
Old Aug 26, 2005 | 02:16 PM
Impala Balko
so they are right on the exhaust manifold... how many O2 sensors are there. Because it said right o2 sensor heater circuit does that give me an indication which one it is
by the way it is a 94
Old Aug 26, 2005 | 04:16 PM
redbullapril23's Avatar
redbullapril23
u have 2 02 sensors. right and left they are right before the cats.
Old Aug 26, 2005 | 05:35 PM
Impala Balko
you mean i dont have 4 i thought i had four
Old Aug 26, 2005 | 05:39 PM
redbullapril23
im pretty sure that only the 96 obdII cars have them as mine has four.
the rear ones are for OBDII emmissions.
Impala Balko
how hard is it to do them are they easy to get at
Old Aug 26, 2005 | 05:43 PM
redbullapril23
not hard to get but hard to break loose. takes a little elbow greese
Old Aug 26, 2005 | 05:45 PM
Impala Balko
is it a harness that plugs into them or do i have to splice wires
Old Aug 26, 2005 | 06:07 PM
redbullapril23
harness that plugs no splicing needed! just follow the wire up.
a large crows foot would be easier to use.. maybe if you dont have ne luck
Old Aug 27, 2005 | 04:00 PM
Impala Balko
is there a way i can test the O2 sensors to see which one i need to replace because i checked and i do have 4 O2 sensors. The code read (Bank 1) Right O2 sensor Heater circuit. Now i have 2 O2 sensors on that bank. which one is faulty due to this reading.
Old Aug 27, 2005 | 04:13 PM
CFI-EFI's Avatar
CFI-EFI
If you have located and checked that the sensors weren't left unplugged, it is time to start trouble shooting. Just because an out of parameter reading came from a given sensor, doesn't necessarily mean that the sensor is bad. Follow the trouble shooting charts in your factory service manual to track down the REAL problem without replacing good parts.
RACE ON!!!
Old Aug 27, 2005 | 04:24 PM
JA94vette's Avatar
JA94vette
My 94 has 3 O2s. Two in front and one on the passenger side behind the cat. From what I understand the one in the back doesn't do anything. And it was put there becuause chevy was going to OBDII. I'm not 100% sure but that's what I heard and it makes sense because of the OBDII ALDL connector but OBD I computer.
Old Aug 27, 2005 | 07:17 PM
Impala Balko
the one in the rear on the pass side is definately hooked up to a connector and a harness so i would imagine it does something
Old Aug 27, 2005 | 08:39 PM
CFI-EFI's Avatar
CFI-EFI
The factory service manual ought to clear up what it does. Without the book, you're just flying blind.
RACE ON!!!
Old Aug 28, 2005 | 12:14 AM
redbullapril23
i agree.
my car was throwing a bank 2 code and the 02 sensors were fine.
Old Aug 28, 2005 | 12:21 AM
JA94vette's Avatar
JA94vette
Thats what I thought but...I saw somewhere on the forum a long time ago that it didn't because it was mid switch between OBD I and II. Anybody know the anwser??
To engine light O2 sensor
