I learned that there is a Dynojet in-ground chassis dyno in the
neighborhood and booked an appointment for today.
Unfortunately, I scrubbed the session because the operator
felt he couldn't tie into the rear tie-down locations ahead of
the rear wheels. His best suggestion was to drop the spare
tire carrier so he could hook onto the differential carrier.
He likewise proposed hooking onto the front lower control arms.
What is the recommended approach to restraining a C4 on
an in-ground dyno?
(I know there is a thread in August where the tie-rod carrier
and/or batwing at the rear and the lower control arms at the
front are suggested. Is this the best that can be done?)
On a C4 I grab the lower struts below the bat wing, or if the spare tire is out, I wrap the straps around the mid bat wing area. I also tie down the front of the car by catching the lower A arms at the front of the car. Strapping the front of the car prevents the car from moving backwards if someone inadvertantly hits the brakes hard while the dyno rolls are still moving.
tjwong, thanks for the restraint information and the caution about
the importance of a front tie-down.
Cinching a car by its suspension members isn't what I wanted
to hear - but I've seen for myself that there isn't much option and
there's no substitute for firsthand experience (your's).
Regards,
Ken R.
ken that is the problem with our C4s there just isn't much to grab onto back there. And it makes it worse if the car has been lowered or for some reason on my dyno, the Corsa mufflers tend to hang at a more acute angle downward going towards the front of the car. This makes grabbing the strut useless because the strap would hit the muffler or pipe which could burn it causing the strap to fail.
It does not sound easy. I really do not know but this is just a thought.
When my car was towed back home they used this little metal inserts that go into the frame in special areas that are made for that.
This " T"s of metal are conected to a strap and then to the platform.
They hold the car in place very well but that is for towing.
I would not know if those parts could be used while putting the car in a dyno.
I looked into that, it wouldn't work for me. At least not on my chassis dyno.
