DYNO set up?
Old Sep 7, 2005 | 08:52 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default DYNO set up?
What things can I do to ensure my car performs at its best on the dyno? Tire pressure? Oil Temps? Water temps low (180 +- 10)???
Old Sep 7, 2005 | 10:50 PM
zelement's Avatar
zelement
You can run 0 weight oil for a little more power, run VP 105 and add more timing. IF you have nitrous make sure you got a full bottle and run it over 1000psi.
Make sure you have the biggest fan you can find blowing right into your intake. If the dyno tech allows, you can keep a bag of ice on the intake the whole time you run.
Other than that just make sure your car is nice and cool.
Old Sep 7, 2005 | 10:53 PM
Lichen's Avatar
Lichen
Try to do it when the outside temperature is as cool as possible.
Old Sep 7, 2005 | 11:12 PM
Perfusion's Avatar
Perfusion
Disconnect the accessory pullies?
Old Sep 7, 2005 | 11:14 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
That's cheating!
Old Sep 7, 2005 | 11:16 PM
Perfusion's Avatar
Perfusion
Originally Posted by Corvette Kid NC
That's cheating!
So's all that other b.s.!!! I wasn't going to say anything, but since you brought it up - it's not setting the car up to "perform it's absolute best", it's setting it up to produce a number that isn't an accurate representation of the car's performance capability on the street or track (bag of ice, 0W oil, etc.).
Old Sep 7, 2005 | 11:22 PM
Lichen's Avatar
Lichen
Well, I dynoed my car when the outside temp was 70*F and got 281RWHP. I went back to the same place when it was 107*F and got 265RWHP. Which am I to believe?
Old Sep 8, 2005 | 12:30 AM
USAsOnlyWay's Avatar
USAsOnlyWay
I would say when its 70* believe 281rwhp and when its 107* believe its 265rwhp.
I wouldn't doubt, not knowing all the other possibly different conditions, i.e. humidity, that it could vary that much in those different temps. Keep in mind, you probably ran a different number than 281 the run before that run so you also have to factor in the run-to-run differences that can happen as well.
Old Sep 8, 2005 | 12:32 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
I had a guy who was crazy about doing over 300rwhp. (mustang) so after we tuned it we still fell about 6hp short.
we aired up the tires to 40psi and put wet rags on the intake and the next pull did 305rwhp.
Old Sep 8, 2005 | 12:33 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
btw by we I meant he.. I had nothing to do with it. I felt like he was wasting our time but he did manage to pull anthor 10rwhp out of it.
Old Sep 8, 2005 | 01:04 AM
vader86's Avatar
vader86
Both, and neither.
I would just set up the car for whatever conditions its actually driven in, 32-35psi tires and no special consideration for anything else, like bags of ice on the intake. A fan wouldnt be special consideration, since on the street you have air coming in anyway.
Otherwise, what good is this special stuff going to do you?
Preferably oil temps would be around 190-200ish, coolant as cool as possible.
Old Sep 8, 2005 | 01:19 AM
steve40th's Avatar
steve40th
I was just curious. I usually just drive in, hook up and let her rip.
Old Sep 8, 2005 | 01:33 AM
zelement's Avatar
zelement
Prepare for a dyno and like you do a race
Old Sep 8, 2005 | 11:32 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
It appears you have a reason for wanting to show the biggest dyno number you can...I look at it a bit differently...I want to show the lowest possible dyno number but still run real quick at the track...I get a big kick out of beating someone at the track and then they ask me how much HP I have...I tell them 278 RWHP (true) and they get all upset...he he he
Old Sep 8, 2005 | 12:19 PM
No Go's Avatar
No Go
I shoot for consistency and let the numbers fall where they lay.
Dyno is great for comparing modifications...but only if things are unchanged otherwise...
Old Sep 8, 2005 | 12:21 PM
LT4BUD's Avatar
LT4BUD
Very interesting........I thought we always looked at CORRECTED ratings that corrected for outside air temperature?????
So even if the actual tested rwhp varies with temperature the reported rwhp should be relatively constant?????
The other question I have is do you correct for outside air temperature or IAT.......these two can be quite different depending on your intake system.....
To get best actual hp you do want your intake air temp to be as cool as possible......hot intake air really kills performance.....]
Old Sep 8, 2005 | 03:02 PM
steve40th's Avatar
steve40th
I am only looking at getting my A/F ratio finalized. I dont care , too much, about the numbers. Its so hot and humid here, numbers are lower than norm anyways. There is no fan going, it is ina one door garage.
To DYNO set up?
Old Sep 8, 2005 | 04:40 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Does he carries wet rags in his rustang for street races?
Old Sep 8, 2005 | 04:43 PM
steve40th's Avatar
steve40th
Wet Rags, Mustang? DO the math
Old Sep 8, 2005 | 04:51 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
I know right.. i'm jsut glad I made the mark on him when he got his new motor..
He said he was going to be dissapointed if it didn't do 480rwhp.. first few pulls where barely 400.. with some work fiinally got it up to 480 without the damn rags, ice, and air pressure
