DYNO set up?
Old Sep 9, 2005 | 12:41 AM
tjwong's Avatar
tjwong
One bit of advice I can offer as a dyno owner/operator. My best advice is for the car owner to make sure that his engine is ready to be run hard on the dyno. As Zelement mentioned, prep it like you are going to race it. Make sure the ignition system intergrity is A OK, fuel system, ie; fuel and air filters and fuel pressure is OK. Fan belts, make sure they are in good condition. I have had several cars blow a belt off at or near the test RPMs. Make mess, not to mention it can be detrimental to my tach pick ups and or causing bodily harm to me or spectators. Make sure you have adequate fuel level in the tank, surprising enough we do consume a good amount of fuel during WOT and even part throttle tuning under load conditions. Got oil leaks? Please fix them before dyno'ing your car. There is nothing more annoying than to have to mop up a nasty puddle of oil after a test session.
Just remember dyno'ing your car is a stress test like on a tread mill for a human So make sure that your baby is in good shape and ready to run. There isn't anything more embarassing aside from unexpected small numbers than your car breaking on the dyne.
Old Sep 9, 2005 | 12:46 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Thanks, It should be ready to go. Only thing is a final oil change.
Old Sep 9, 2005 | 12:53 AM
FD2BLK's Avatar
FD2BLK
Originally Posted by LT4BUD
Very interesting........I thought we always looked at CORRECTED ratings that corrected for outside air temperature?????
So even if the actual tested rwhp varies with temperature the reported rwhp should be relatively constant?????
I don't know about all Dyno software but there is a point where it will not corrrect. My last run on the dyno jet dyno, 105 deg, the software came up with an "unfair compairison" warning when we tried to compair my run on a 67 deg day.
