Coolant loss ?
Old Sep 8, 2005 | 09:53 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Coolant loss ?
I am losing coolant and I am getting some smoke out the back. Where is the best place to look for a coolant leak into the engine?
Old Sep 8, 2005 | 10:01 AM
rick lambert's Avatar
rick lambert
What kinda smoke-sure it's not steam. I'd be checking my engine oil first to make sure coolant wasn't getting in the oil-exhaust smoke-or steam and coolant loss could indicate a blown head gasket. How are your engine temps? Maybe time for a compression or leak down test.
Old Sep 8, 2005 | 11:52 AM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
...and take this problem seriously. The water boils off, but the Glycol coats wear surfaces and inhibits lubrication.
Old Sep 8, 2005 | 02:20 PM
jabez's Avatar
jabez
Check the hoses. you don't want the coolant hitting your OPTI.
Old Sep 8, 2005 | 03:58 PM
vader86's Avatar
vader86
head gasket
Old Sep 8, 2005 | 05:27 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Temps a little high, no coolant in oil. No, I know it is smoke from coolant. Just want to know the likely spots for coolant leakage into heads on a LT1. Intake manifold or head gasket?
To Coolant loss ?
