Need new engine or rebuilt
Old Sep 10, 2005 | 08:41 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Need new engine or rebuilt
I have 139k miles and leaks everywhere and now I am starting to hear valves on passenger side, plus a noise from the same side. Can't really tell you what noise sounds like but it is pretty loud. Advance has a rebuilt for $699 w/1yr warrenty, has anyone used this engine or am I better off having it rebuilt?
Old Sep 10, 2005 | 08:53 PM
tjwong's Avatar
tjwong
Never heard of them, where can they be purchased. You may want to check with Jasper Engines from Jasper Indiana, they have good deals on reman engines as well.
Old Sep 10, 2005 | 08:55 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
I am not familiar with, and don't know anyone who has used that engine. Are you looking to spend as little as possible? If not, what is your budget for the engine? Can you do any of the work yourself? There are a few very nice crate engines out there that will give you a nice performance increase, too.
Old Sep 10, 2005 | 08:58 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Check out 350 engines.com. They have a 7 yr/70,000 mile warranty. Might be worth looking into.
Old Sep 10, 2005 | 09:21 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Money is a little tight(daughter in college), want to keep it under $1k.
Cant' do any heavy work, I tore up my shouler in an accident.
Old Sep 10, 2005 | 09:54 PM
STL94LT1's Avatar
STL94LT1
Are you sure that is the price for an LT1, not just the standard 350? Sounds awful cheap to me.
-Mike
Old Sep 10, 2005 | 10:16 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
For a corvette,I would not use a chain stores reman motor.You have no idea what the quality of the work is gonna be,it can be excellent,hit or miss or awful.I have seen some of their displays and seen their rebuilt heads and transmissions laying around but always thought it was best to have YOUR engine fixed,and knowing what it needed and etc rather than buy another old core that was rebuilt by company X.
When I pulled my L98,I got it rebuilt for around 1500 by a decent shop that specialized in fixing GM engines,GM cars and trucks.The machine shop was very knowledgable and was flexible to work with the budget.You dont always need high performance work that will set you back alot more $$$.
Were you planning on having someone help you pull your engine or have a shop do it for you?
Good Luck!
To Need new engine or rebuilt
