cam question
Old Sep 11, 2005 | 02:57 PM
pr0zac's Avatar
pr0zac
Default cam question
i bought an lt1 short block off of ebay ealrier this year and it had a almost new cam in it. i know its not the original cam cause it has a fuel pump lobe on it. the numbers on the back say
586 FM13
216 00R
can anyone tell me what it is. i know is its a gm cam but have no specs. thanks
Old Sep 11, 2005 | 03:07 PM
pr0zac's Avatar
pr0zac
i am guessing its a hot cam casue it seems to be the only gm cam that is made for an lt1/4 engine with a long dowel pin.
Old Sep 12, 2005 | 03:14 AM
rodj's Avatar
rodj
What color is the painted stripe?
My hot cam has
586AC.104
075
04R
stamped on it
Old Sep 12, 2005 | 11:13 AM
pr0zac's Avatar
pr0zac
white
Old Sep 12, 2005 | 11:26 AM
tjwong's Avatar
tjwong
I got a GM847 direct from GM and it had a long pin in it as well. It could be a new stock cam that was removed for a hot cam replacement.
Old Sep 12, 2005 | 11:39 AM
pr0zac's Avatar
pr0zac
how can you tell which gm cams are which. if this thing is a 847 i am swaping it out with my xfi280 today! i know the car that the engine was in had a supercharger on it cause it had a return hole in the oil pan.
Old Sep 12, 2005 | 07:17 PM
rodj's Avatar
rodj
Hot cam has yellow / greenish stripe
Old Sep 12, 2005 | 08:55 PM
rrubel's Avatar
rrubel
A google search gets me an FM13 cam used in an LS1 with specs (.230/.232 .595/.585 112) and made by Futral.
[RICHR]
Old Sep 12, 2005 | 09:05 PM
95PoloVert's Avatar
95PoloVert
Active Streak: 90 Days
586 FM13
216 00R
I went through this with a Hot Cam I bought last year.
The 586 indicates that it is a GM Hot Cam. It may or may not have a stripe of any specific color. The rest of the numbers pertain to Lot ID, etc.
Specs are...
218/228 @ .050
.525/.525 lift with 1.6 ratio rockers.
112 * LSA
Old Sep 12, 2005 | 11:42 PM
pr0zac's Avatar
pr0zac
i feel dumb now for asking that question cause i just realized why they call the 847's, 846's, etc. the 586 is the last three digits of the hotcam part number. i didn't even think to match them up. thanks for the help. i got to find an engine to put it in now.
To cam question
