1st to 4th
Old Sep 17, 2005 | 01:40 PM
polo92's Avatar
polo92
Cruising
Default 1st to 4th
new owner of a 92 I would like to know where to disconnect the (cags)
system
Old Sep 17, 2005 | 01:54 PM
Perfusion's Avatar
Perfusion
If you're under the car, it's on the driver's side of the transmission up a little ways in the tunnel. You can't miss it, though - wires and a plug. If you're going to disconnect it, try to do something to protect the open ends from road grime, water, etc. A kit from MidAmerica or your local Corvette Parts place would be ideal...
Old Sep 17, 2005 | 01:57 PM
FD2BLK's Avatar
FD2BLK
LOL,
That is the first thing that I did to my car. You hav ethe 92 so it will not trow a code. The CAGS by pass kit does make for a clean intstall that covers the connector ends to prevent gunk from getting in there but you can do the same thing with heat shrink or even a plastic bag and a ty-wrap. Now to answer your question get under the car and on the drivers side it will be the flat connector about 1/2 way down the trany near the top.
Old Sep 17, 2005 | 02:24 PM
pablocruise's Avatar
pablocruise
CAGS and ZF synchros don't like each other
The round solenoid in the middle there.
Old Sep 17, 2005 | 03:17 PM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
In my opinion, no need for the kit. Just unplug it and use electrical tape to cover the ends. All set! It should take about 10 minutes or less!!!!
To 1st to 4th
