Headlight clicking
Old Sep 19, 2005 | 01:40 AM
Phantom90's Avatar
Phantom90
Default Headlight clicking
I recently replaced the headlamp bushings and gear in my left headlamp. As far as I know I put everything back where it was suppossed to go.
Once I turn the lamps on or off they make about ten LOUD clicking sounds.
Does anybody know what it is? What I need to do?
Old Sep 19, 2005 | 08:13 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Well, something obviously didn't bolt back together properly.
I hate to tell you this, but I'd check those bronze shims (washers) and the motor casing itself.
They're both close-tolerance items and must be assembled properly in order for the gears to mesh.
The first time I overhauled my headlight motor, I failed to bolt it back together properly and it made the same noise you're describing.
Old Nov 22, 2005 | 08:19 PM
robertpel9's Avatar
robertpel9
I am having the same issue but i did not just fix anything it just started. Same EXACT issue. What is it??
Old Nov 23, 2005 | 12:05 PM
eptaylor's Avatar
eptaylor
Where did you get the bushings? If they are the Home Depot one's that could be the problem. When I used them they got crushed due to inadequate wall thickness.
To Headlight clicking
