Torque settings for Runners needed please
Old Sep 23, 2005 | 08:09 PM
smacko's Avatar
smacko
Default Torque settings for Runners needed please
Hi;
The Haynes manual I have doesn't seem to list what I need, which is;
Torque settings for Runners to intake manifold
Torque settings for Runners to plenum, both for my '85.
I'm guessing they'll be in the vicinity of anywhere from 15 - 25lbf
...I doubt they'd say 30flb for this application.
Old Sep 23, 2005 | 08:15 PM
bogus's Avatar
bogus
I am digging from memory here... but I think it's 18ftlb.
To be honest, the key here is consistancy.
Old Sep 23, 2005 | 09:00 PM
smacko's Avatar
smacko
Cheers, yeah I realise consistency is more the point for warpage reasons.
Anyone else have the factory settings?
Old Sep 23, 2005 | 09:08 PM
SupaVette's Avatar
SupaVette
they are 25
Old Sep 23, 2005 | 09:14 PM
smacko's Avatar
smacko
Originally Posted by SupaVette
they are 25
I thought they may be.
IS that from the GM manual or something else?
Old Sep 23, 2005 | 09:15 PM
scorp508's Avatar
scorp508
23 rings a bell for some reason. I just make em' good and snug.
Old Sep 23, 2005 | 09:17 PM
smacko's Avatar
smacko
Thanks. I'm not really after any bell ringings or memories, just ACTUAL factory specs.
Old Sep 23, 2005 | 09:20 PM
scorp508's Avatar
scorp508
Sorry for trying to help. Trust me, you won't **** off any corvette gods by being off a couple ft. lbs.
Old Sep 23, 2005 | 09:22 PM
smacko's Avatar
smacko
No mate, SORRY - I didn't mean it to sound that way! I DO appreciate your thoughts. I'd just like to know the exact range GM specifies on this and decide for myself the amount of variation.
bogus's Avatar
bogus
besides, it's a steel bolt going into aluminum... err on the side of caution.
Old Sep 23, 2005 | 09:27 PM
smacko's Avatar
smacko
EXACTLY my caution; don't want to go any higher than recommended...In fact I'll prob go 1 or 2 pounds lighter
Old Sep 23, 2005 | 09:35 PM
Casethecorvetteman's Avatar
Casethecorvetteman
so which one is it? 18, 23 or 25 ft/lbs?? Thats a big variation isnt it...
Old Sep 23, 2005 | 09:38 PM
bogus's Avatar
bogus
the 18lbs setting is from the Edelbrock kit, to be honest, so they may have different requirements.
Old Sep 23, 2005 | 09:53 PM
Morley's Avatar
Morley
Bogus is right...19 ft/lbs, even for the factory pieces. What I do is run them all down till they are snug, then go 1/8 turn more..this is about 15 ft/lbs.
Old Sep 23, 2005 | 10:27 PM
smacko's Avatar
smacko
Yeah mate, I thought it was a fairly straight forward question too...
JUST to be MORE precise; My runners are STOCK '85 ones and they're going into STOCK '85 Inlet manifold.
Might take a closer look at the Haynes manual...
Old Sep 26, 2005 | 08:26 AM
SupaVette's Avatar
SupaVette
From my gm book for a '90 25ft/lbs
Old Sep 26, 2005 | 08:41 AM
Casethecorvetteman
He has an "85" though... BIG difference....
To Torque settings for Runners needed please
Old Sep 26, 2005 | 09:07 AM
smacko's Avatar
smacko
Thanks, but as 'casethecorvetteman' says; there's a BIG difference between '90 & '85, and I DID state right at the beginning, mine is an '85.
CORRECT GM specs from a CF mate Bob (I forgot his nickname) IS 18.
Old Sep 26, 2005 | 12:29 PM
Morley's Avatar
Morley
No difference. same cast aluminum parts
Old Sep 26, 2005 | 12:34 PM
scorp508's Avatar
scorp508
There is absolutely zero difference between 85 and 90 plenum/runners as far as fastening goes. The only difference you'll find is that the intake manifold itself the bolts are at a different angle, the cold start valve does not exist, and there is no rear coolant line. If anything I'd more trust the later #s since '85 was a "first year" engine.
