Valeo clutch ok?
Old Sep 25, 2005 | 08:35 AM
1990C4 ConvertUK's Avatar
1990C4 ConvertUK
Default Valeo clutch ok?
I've got the chance to get a valeo stage 1 clutch kit and a single mass flywheel for my 1990 6 speed, so
1) Never heard of Valeo clutches so any opinions on quality and benefits of stage 1 over standard welcomed
2) What should I expect if I go for the single mass fly wheel? Better performance? durability?
Any feed back greatly appreciated!
Old Sep 26, 2005 | 09:31 AM
dchildress's Avatar
dchildress
BUMP
I would like an opinion also.
Old Sep 28, 2005 | 01:01 AM
383LPE's Avatar
383LPE
valeo is oem. the smf depends if it is aluminum or steel. search will help.
Old Sep 28, 2005 | 01:42 AM
500hp's Avatar
500hp
Valeo builds almost all the LT1/T56/ZF6 pressure plates (complete or cores) used by the various clutch vendors. Some companies sell them in their stock form as they come from Valeo, others, like Centerforce, modify them for particular applications requiring special features, or for use with a weird clutch disc. I have heard the stock GM version can handle 500 HP with a stock type disc. Being a pull style, as opposed to a push style, they seem to have plenty of clamping force for most street applications. From there, the clutch disc choice becomes the limiting factor, which will vary from one company to another. If the Valeo pressure plate can't hold onto a full kevlar puck style disc, you probably need to step up to a multiple disc race set-up.
Old Sep 28, 2005 | 02:05 AM
500hp's Avatar
500hp
The dual mass flywheel weighs around 38lbs. A steel, or iron, single mass flywheel will weigh between 16 and 20lbs depending on manufacturer (Iron GM F-body is around 16lbs, aftermarket billet steel are around 20lbs.). The aluminum versions are 12 to 13lbs. The clutch and Valeo pressure plate weigh in at 20 to 24lbs. The ZF6 dual mass flywheel wears out in two places (clutch surface and between the two masses) and cannot be rebuilt, and should not be resurfaced. I recommend the aluminum flywheel with its replaceable steel surface insert. The iron or steel versions would be the least expensive and still an improvement over the stock piece.
Old Sep 28, 2005 | 09:24 AM
tjwong's Avatar
tjwong
Valeo clutches are fine to use. Even Mcleod Industries that manufactures the famous street twin for the LTx and L98 engines uses a Valeo pressure plate with their street twins.
Old Sep 28, 2005 | 02:56 PM
1990C4 ConvertUK
Default Thanks
Valeo stage 1 clutch purchased, fitted next week!
Old Sep 28, 2005 | 06:57 PM
Atok's Avatar
Atok
Valeo in mine!
Old Sep 29, 2005 | 04:25 PM
sickspeedvette's Avatar
sickspeedvette
Just remember, it's going to sound like hell idling with the clutch engaged. Mine does anyway.
Old Oct 24, 2020 | 01:09 PM
B Rogers's Avatar
B Rogers
1st Gear
Default Valeo stage 2 clutch
I was about to change my clutch and slave cylinder on my 01 c5 with 112,000 and I was wondering would be the Valeo stage 2 be ok. Only mods are long tube headers, air intake and a tune.
Old Oct 24, 2020 | 04:23 PM
Kevova's Avatar
Kevova
Resurrecting a 15 year old thread in the wrong sub forum. I suggest you start your own new thread in the C5 Forums.
To Valeo clutch ok?
