'88 L98 rough idle - code 32 (EGR)
Old Sep 26, 2005 | 08:48 AM
tmcorvette's Avatar
tmcorvette
Default '88 L98 rough idle - code 32 (EGR)
Hi all,
In the morning my car's engine ('88 L98) got rough idle (yanking, stuttering) so it is not running smoothly.
I checked ECM codes and I found code 32. This means EGR line failure.
If I change EGR valve can solve this problem? What should I check more? Thnak You.
Old Sep 26, 2005 | 09:42 AM
AFogleman's Avatar
AFogleman
There is an Egr solenoid on the rail on the driver side.Mine went bad.Replaced it and all worries gone Hope this can help you.Also check for a vacum leak.
Old Sep 26, 2005 | 09:48 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Before any money is spent follow these diagnostics. They are from my 86 manual. http://members.shaw.ca/corvette86/Code%2032.pdf
Old Sep 26, 2005 | 09:52 AM
AGENT 86's Avatar
AGENT 86
Heres some more from the manual. http://members.shaw.ca/agent86/EGR%20System.pdf
Old Sep 26, 2005 | 10:08 AM
tmcorvette's Avatar
tmcorvette
Thank You guys for your fast help! Have a good day.
To '88 L98 rough idle - code 32 (EGR)
