Can Someone Verify This Prom (late 86)
I replacing my hypertech chip(calpack) with a stock one from AC Delco. They don't mention aluminum heads in any of the listings but one does say "without rpo iron heads". Process of elimination says this is it. Is it
16063919 EPROM,ECM
With RPO 4-SPD M/TRANS(MH5) ^ 3.07R(G44) CODE 3921AARK,8934AML Without RPO CAST IRON HD(KB2
Heres what i had to choose from;
Qty Req Qty ACDelco Part# Description
ENGINE / COMPUTER PROM/CHIP
01 1227942 EPROM,ECM
With RPO 4-SPD A/TRANS(MD8) ^ 2.59R(GM1) ^ CAST IRON HD(KB2) CODE 9355BUC,9555BUC,1724BUC
01 1227943 EPROM,ECM
With RPO 4-SPD M/TRANS(MK2) ^ 3.07R(G44) ^ CAST IRON HD(KB2) CODE 9348BUB,1726BUB Without RPO EUROPEAN PROVISIONS(VD1)(EXPORT)
With RPO 4-SPD M/TRANS(MH5) ^ CAST IRON HD(KB2) CODE 9398BUM
01 1227944 EPROM,ECM
With RPO 4-SPD A/TRANS(MD8) ^ 3.07R(G44) CODE 1728BUA,9340BUA Without RPO LEADED FUEL EMIS EXPORT (NM8) ^ (VE1)(EXPORT)
01 1228107 EPROM,ECM
With RPO 4-SPD A/TRANS(MD8) ^ 2.59R(GM1) ^ 2.73R(GU2) CODE 1732AANK Without RPO CAST IRON HD(KB2)
01 1228109 EPROM,ECM
With RPO 3-SPD A/TRANS(MD2) ^ 2.73R(GU2) ^ 3.07R(G44) CODE 2770AANM,0504AMH,1736AANM Without RPO CAST IRON HD(KB2)
With RPO 4-SPD A/TRANS(MD8) ^ FEDERAL EMIS(NA5) CODE 4045AANL,8840ALZ,1736AANM Without RPO CAST IRON HD(KB2) ^ LEADED FUEL EMIS EXPORT (NM8) ^ (VE1)(EXPORT)
01 1228473 EPROM,ECM
With RPO 4-SPD M/TRANS(MK2) ^ 3.07R(G44) CODE 0499AMJ,1734AARL,1010AARL Without RPO CAST IRON HD(KB2)
With RPO 4-SPD M/TRANS(MK2) CODE 8848AMA,1734AARL,1010AARL
01 16063919 EPROM,ECM
With RPO 4-SPD M/TRANS(MH5) ^ 3.07R(G44) CODE 3921AARK,8934AML Without RPO CAST IRON HD(KB2)
01 16059672 EPROM,ECM **VPI 1-877-846-8243
With RPO 4-SPD M/TRANS(MK2) ^ CAST IRON HD(KB2) ^ EUROPEAN PROVISIONS(VD1)(EXPORT) CODE 9676BUP
16063919 EPROM,ECM
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Man, How much is this gonna cost? You might just want to save your money and do a Prominator.....
This is the one for my engine. I selected it based on trans and ratio. All others didn't fit.
The 1728BUA and 9340BUA are the program chips. the 1728 is an early version and the 9340 has been updated to stop throwing false codes. I tried one of each (borrowed from others) and found that both ran equally as well. Of course neither ran as well as the custom tune.. If your shifting to a Prominator you'll only need the Memcal for the limp home mode.
My plan is to go to the prominator next year. When i remove the hypertech calpack i'm left with nothing so i need a stock calpack in order to use the G1 adapter and prominator. It's going to cost me $50 cad for the stock chip which will be recouped when i sell the hypertech.
Originally Posted by C4forlife
hey guys how does the Prominator system work? Do you have the ability to program more freely as with an eeprom setup?
Read these 2 pages.
http://misterbill.homeip.net/aboutprominator.asp
http://prominator.homeip.net/forum.asp?FORUM_ID=32
I've had mine running since the spring and am very pleased.
The best part is, you upload to the Prominator via the parallel port from a PC. The software comes with the chip. You can do this anytime you please and the engine can be running! Now for the novice whom doesn't have time to learn how to program, you can pay PCMsforless and nominal fee of 75 bucks and email Alvin the datalog log files and he emails you the bin files to upload to your chip. For the dyno day this can be one hell of a time saver since the upload only takes seconds from receipt of the email.
My 86 has been running great ever since Alvin took care of the tuning.
Originally Posted by scorp508
I'm thinking of purchasing one of these, but the ordering part of the site seems to be down for redesign. Anybody know what the PRO version costs?
