HELP. Missing and white smoke
Old Oct 3, 2005 | 11:02 PM
C4kid94's Avatar
C4kid94
Default HELP. Missing and white smoke
For the last couple months my car had slight miss everyonce in awhile, it would make sort of a burbling sound.it only lasted a couple seconds and it did not happen all the time just every once and awhile.
Recently it has started to run horribly, at idle the car will shake because of it missing so badly, and when you drive it barely goes and misses badly, ive also noticed a little white smoke, I mostly notice it when i leave from a stop or free rev it.
My car has a new opti and ignition system so i dont think it is that, im thinking maybe bad injectors? anyone have any ideas?
Thanks for your help in advance.
Old Oct 3, 2005 | 11:04 PM
bogus's Avatar
bogus
nope... not injectors... it's a head gasket.
pull the plugs... if they are white, you need to tear that thing down - ASAP!!!!
Old Oct 3, 2005 | 11:10 PM
aboatguy's Avatar
aboatguy
White cloud from the exhuast =water
Mike
Old Oct 6, 2005 | 12:10 AM
2 GRUMPY's Avatar
2 GRUMPY
Default White Smoke
I Feel Your Pain !!! I Just Got Through Replacing The Intake,and Valve Cover Gaskets After Finding Oil And Anti Freeze Running Down And Burning On The Block And My 1991 Red Coupe Only Has 65,000 Miles !!!!!!
Old Oct 6, 2005 | 12:33 AM
2 GRUMPY's Avatar
2 GRUMPY
Default Whie Smoke
I Feel Your Pain!!!!! I Just Finished Replacing The Intake And Valve Cover Gaskets After Finding Oil And Anti Freeze Running Down And Burning On The Block And My 1991 Red Coupe Only Has 65,000 Miles.
Old Oct 6, 2005 | 01:25 AM
Frizlefrak's Avatar
Frizlefrak
Mike
What these guys said. Coolant will not do your engine internals any good, particularly the lower end (it makes a lousy lubricant).
Stop driving it until it's fixed.
Old Oct 6, 2005 | 10:02 PM
SUNNYD 95's Avatar
SUNNYD 95
Default White smoke
I would say you might have a head gasket blown, fix it now before it gets worse
Old Oct 8, 2005 | 12:35 AM
AILERON's Avatar
AILERON
Blown head gasket - tear it down if you intend to keep it - if not sell it as is - just be sure to let the victim, ummean customer, know what he's getting. Good luck.
Old Oct 8, 2005 | 02:08 AM
vader86's Avatar
vader86
Yep, thats a head gasket. Time for you to spend some $$$, hopefully you can do some yourself.
To HELP. Missing and white smoke
