Throttle Body Spacer?
Old Oct 5, 2005 | 07:27 AM
Red Tornado's Avatar
Red Tornado
if you want power, either build it right from the inside out by doing cam/heads/intake/exhaust. and maybe more cubes. otherwise you're jerking yourself around and getting nowhere fast. fast & fun comes does not come in a $50 trinket.
Old Oct 5, 2005 | 07:31 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Originally Posted by Fork501
Has anyone ever tried the Throttle Body Spacer? I have an '88 L98 with a stock TB. I found one at Ecklers for $120, but I'm not going to buy it if it does squat. If anyone HAS tried it, do you know where to get it for cheaper? Other spacers for other cars sell for about $60-$90.
Thanx in advance!
~Derek
I can save you 50% with the same results!
Send me $60 and I'll pray real hard for you to go faster!
Seeya
Old Oct 5, 2005 | 07:53 PM
Fork501's Avatar
Fork501
Seeya
Old Oct 5, 2005 | 09:42 PM
Biff Buyer's Avatar
Biff Buyer
if you want some real HP numbers. Add some Vinyl. Depending on the size, it can add close to 50 RWHP. Now dont get me started on neon lights and the cool little dice you can hang from your rear veiw mirror... The possibilities are endless from there.
Old Oct 5, 2005 | 09:53 PM
Fork501's Avatar
Fork501
Actually, I bought me a keychain about a week ago and immediately noticed the 25 rwhp =)
Old Oct 5, 2005 | 09:58 PM
Biff Buyer's Avatar
Biff Buyer
if theres a style of car i hate, it would be ricers and tuners. Cheap peices of japanese plastic hardware with their weedwacker mufflers and huge wings that create drag and lifts the front up on front wheel drive cars.
Old Oct 5, 2005 | 10:43 PM
kopbet89c4's Avatar
kopbet89c4
REeally, what would the purpose of the TB spacer be? Is it supposed to be a decoration of some sort? What is theory behind having one? Just curious...
Old Oct 5, 2005 | 10:44 PM
kopbet89c4's Avatar
kopbet89c4
Then you'd really get no traction but a nice slow 3.5 second 60'
Old Oct 6, 2005 | 03:28 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I think the basis was to extend the effective "runner" length on carbed and TBI cars. It's been around longer than fuel injection. The longer this distance below the butterflies is, the more developed and balanced flow you get to the cylinders, ie... better and more balanced volumetric efficiency. Note that there is no plenum on these types of intakes.
Now... the MPFI... adding a spacer only increases the size of the plenum slightly. Notice how no care is taken to make the plenum aero-friendly... wierd casting features everywhere, is perpendicular to the runners... look at the superram, it's just a big misshaped box. The plenum's job is only to provide a large air volume at a consistent pressure for the entrance of every runner tube. The shape and aero inside it is not important. This helps the cylinder 5&7 inversion on most 90* V8s. (On SBFs, this would be the #7,8 cylinders, firing order is actually the exact same, just labelled different)
So... if you were to try and fab a spacer for mpfi cars, it'd have to extend the length of each individual runner. But, you already have established flow with such long runners, that you're well beyond the point of diminishing returns.
