Which Header w/ angle plug heads
Old Oct 13, 2005 | 05:09 PM
q2blaster@work's Avatar
q2blaster@work
Default Which Header w/ angle plug heads
Which headers are best fitting on my 85 l98 w/ angle plug bowtie heads??
Old Oct 13, 2005 | 08:02 PM
q2blaster's Avatar
q2blaster
Default anybody
How about this, TPIS or Hooker which do you prefer?
Old Oct 13, 2005 | 10:38 PM
JackDidley's Avatar
JackDidley
I have non L98 angle plug heads and the TPIS makes plug access very easy.
Old Oct 14, 2005 | 11:20 AM
q2blaster@work
Default okay
Ordered tpis coated this morning, thanks for your input!!
Old Oct 14, 2005 | 12:35 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Default after the fact
I have TPIS with my angle plug heads - no problems.
Have fun with that Y pipe
Old Oct 14, 2005 | 12:46 PM
Slalom4me's Avatar
Slalom4me
The SS pipes from Stainless Works fit very nicely on
my '89 and plug access is not an issue.
Incidentally, you might want to plan to place some
heat shielding around the Fan Switch that threads
into the head on the driver's side (if you have the
aux fan). The heat from #1 pipe seems to cause
a false reading otherwise and you may find the fan
engaging at a lower temperature.
ThermoTech and DEI sell material that can be placed
over the wire and sensor.
To Which Header w/ angle plug heads
