Diff Gear measurement
Old Oct 14, 2005 | 03:04 AM
rodj's Avatar
rodj
Default Diff Gear measurement
Have a seller trying to identify whether he has D36 or D44 gears for sale.
Where do you measure the crownwheel ( to get the 8.5" for a D44)?
Across the teeth or across the mounting face as gears are angled and diameter larger across teeth side
Old Oct 14, 2005 | 05:08 AM
k99ja04's Avatar
k99ja04
I believe there is a casting number on the housing. Should be different for each.
What year vette did it come from? If you know the tranny the rearend was bolted to, automatics came with a D36 and manuals came with D44.
Old Oct 14, 2005 | 11:52 PM
rodj's Avatar
rodj
I know this.
The seller has acquired these parts, has no knowledge of source.
Has a diff head with stuffed gears and a crownwheel / pinion combo which may or not fit..
Want to know where D44 8.5" measurement is taken as in 9" Ford ; is it measured across the teeth (most likely ) or across the mounting face?
Old Oct 16, 2005 | 05:43 PM
Chest-nut's Avatar
Chest-nut
Why would you consider buying "USED" differential gears anyway???????
On a deal this expensive and time consuming go with new gears only. Gears may look good, but think how bad you would feel on your first drive after the install and hear a hi-pitched whine coming from thr rear.
Old Oct 17, 2005 | 07:57 AM
rodj's Avatar
rodj
BECAUSE I live at the OTHER END f the world to you and don't have the convenience of dropping in to Walmart on the way home to buy a set of D44 gears.
C4's are expensive (try US$20K + for a '87) ,fairly rare and parts even more so.
Shipping from the US virtually doubles the price YOU pay plus duties , so when a deal comes along it is worth checking out.
To Diff Gear measurement
