Plug gap on Stock 85
Old Oct 16, 2005 | 07:25 PM
dbaker's Avatar
dbaker
Default Plug gap on Stock 85
The sticker under the hood says gap recommendation was changed from.045 to .035.
Since the plugs are a pain to change,I want to get it right.
Would appreciate any help.
PS: I have a K&N short intake coming and will be installing a stage 1 chip soon.
\db
Old Oct 16, 2005 | 07:27 PM
Pete K's Avatar
Pete K
Either will be fine. "I" would only go .035 if it were me. Bigger gaps tend to put more strain on the ignition system with (imho) no gain. I run mine at .030. Nitrous has a habit of blowing out the flame, so I shrink it up for safety.
Old Oct 16, 2005 | 08:26 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
.035. I might consider going higher if I had an aftermarket coil, or if I knew more about the science behind spark plugs.
Old Oct 16, 2005 | 10:00 PM
Morley's Avatar
Morley
The .045" was the original factory setting...then they had a lot of ignition modules burning out and traced it down to the larger plug gap stressing the modules...so they changed the gap to .035"...use that.
To Plug gap on Stock 85
