Performance Injectors
Old Oct 21, 2005 | 12:10 AM
949C1's Avatar
949C1
3rd Gear
Default Performance Injectors
I'm building a '94 LT1 Turbo engine, What are the best injectors around? What are the best priced injectors and still get me buy. The LT1 has ported heads 1.6 RR, 8.5 Compression, Stroked to 383, and forged everything. I want to get the best performance out of it but still be streetable.
Old Oct 21, 2005 | 12:14 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
I'm really happy with my motron 65's They do great as far as driveablity (probally better than my 42's believe it or not)
The 65's are good up to probally 650-700rwhp.
Old Oct 21, 2005 | 11:19 PM
949C1's Avatar
949C1
3rd Gear
Cool where can I find these injectors? I tried doing a search and could not find a supplier.
Old Oct 22, 2005 | 12:23 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
Ebay or racetronix
Old Oct 22, 2005 | 01:30 AM
Racetronix's Avatar
Racetronix
Supporting Vendor
Sounds like the Siemens 3172's or Siemens L107's would be in order here. Stay away from the Delphi 17113738's as they do not tune easily with the LT1 & LS1 PCM's.
Both the 3172's and L107's are in stock in flow-matched sets.
Old Oct 22, 2005 | 09:57 AM
Brand-X's Avatar
Brand-X
Do you guys make a fuel system for the LT1 vette that can support 1k hp?
Old Oct 22, 2005 | 11:44 AM
tjwong's Avatar
tjwong
Why are the Delphi/Multec 3738 injectors hard to tune? Are there some inherent problems with fuel metering at low engine loads and or low engine speeds?
Old Oct 22, 2005 | 03:36 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
We manufacture harnesses etc. to assemble double in-tank systems which are available to dealers listed on our web page such as Blowerworks. These systems are capable of supporting upwards of 1000HP depending on the configuration. Please contact Blowerworks to discuss your requirements.
Old Oct 22, 2005 | 03:46 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
The 17113738 is a very slow/ lazy injector plus the electromagnetic properties of the coil in combination with some ECM/PCM drivers cause erratic fueling. These injectors seem to work very well with GN's, Sy's Ty's, L98, Mustangs etc. Based on feedback from our dealers and customers most people are not able to obtain good results with them. That is not to say that it can not be done as we do have some customers running them in LT1 and LS1 cars but they are few. The Siemens 3172 and L107 are much easier to tune for most people.
Old Oct 22, 2005 | 05:48 PM
AKS Racing's Avatar
AKS Racing
Siemens 83 lb/hr injectors here.
Old Oct 22, 2005 | 07:29 PM
Baldturbofreak's Avatar
Baldturbofreak
Are the L107's E85 compatible? Do they come in shorty's?
Old Oct 22, 2005 | 07:38 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
Mototron has stated the following:
"They are rated for 85% methanol and people have used them with 100% methanol with no problems."
Standard 20% ethanol for gasohol is OK too.
Shorty's are listed here: http://www.racetronix.com/S107FM.html
Old Oct 22, 2005 | 07:53 PM
Baldturbofreak
very cool, thanks
Old Jan 17, 2006 | 12:55 PM
snidely1440's Avatar
snidely1440
Default bran of turbo?
What brand of turbo are you using and did you or are you going to reprogram the ecm? You should post some pics.
Old Jan 17, 2006 | 03:27 PM
Mo_Bandy's Avatar
Mo_Bandy
I'm using the Mototron 60's here... Very good thus far, I'm still tuning received them a few days ago...
Mo
Old Jan 17, 2006 | 11:31 PM
Baldturbofreak
That is the first I have heard of that phenomenon, I wonder If that explains some of bruce's woes. Those are his exact injectors (17113738 ) Very inconsistent fueling.
Old Jan 18, 2006 | 07:51 AM
Bruce's Avatar
Bruce
This is maybe true with the 50s . But we won't have that problem with the GEN 7 ECU to drive the big Delphi 96s I got now.
Old Jan 18, 2006 | 11:10 AM
Baldturbofreak
For sure! those nice Peak and hold drivers will snap those babies open with AUTHORITY!
Old Jan 18, 2006 | 05:15 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
Low-Z Multec 1 and PH drivers are a totally different thing.
This only applies to P/N 17113738
To Performance Injectors
