hvac and stereo problems
Old Oct 31, 2005 | 09:17 AM
rightofway's Avatar
rightofway
Default hvac and stereo problems
i have noticed recently that my stereo was acting up (i.e. the display would go out, the station would change randomly and, it sometimes would just not work but the antenna always went up) on my way to school just now the station changed and the display went out then the climate control unit started acting up. it turned of my front defroster and put on the hatch one the display went out then acted up.
WTH is goin on with my car? are these problems related? is it possessed?
Old Oct 31, 2005 | 09:35 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
They both share the ctsy/clk fuse. Seems like a good place to start
Old Oct 31, 2005 | 09:40 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Might it be just a ground (negative wire) problem?
Check your wiring diagram and see if they all share the same ground location. If so, try cleaning and retightening it and see if it solves the problem
Old Oct 31, 2005 | 10:30 AM
vader86's Avatar
vader86
Same fuse, contacts on the back of each my need cleaning...
To hvac and stereo problems
