Back from the dyno---466RWHP
Old Nov 3, 2005 | 05:50 PM
Zix's Avatar
Zix
Default Back from the dyno---466RWHP
What a difference a functioning ignition and a tune make! After 3+ hours on the dyno and 15+ pulls we stopped at 466 RWHP and 431 RWTQ. I was MORE than happy with the results! The car still has some more in it but I didn't want to rev it over 7K as I just replaced some of the main bearing a couple hundred miles ago and I was being paranoid...
Here's a scan of the printout...
It's a 383 LT4. My exhaust it REALLY choking up top right now too...with a better flowing exhaust and a set of shaft rockers I can probably get another 20+HP out of it...but considering this thing took me 10+ months to finish I think i am going to take a break for now!!
Old Nov 3, 2005 | 05:56 PM
FD2BLK's Avatar
FD2BLK
Is that with the stock Lt intake? I just havent seen much over 450 to the rear wheels on a N/A LT intake
Old Nov 3, 2005 | 06:01 PM
Zix's Avatar
Zix
It's a ported LT4 intake
Old Nov 3, 2005 | 06:14 PM
LD85's Avatar
LD85
Outstanding, the LT4's really are an excellent base for "more"
Old Nov 3, 2005 | 06:21 PM
Gary K's Avatar
Gary K
Awesome. What heads and cam are you running?
Old Nov 3, 2005 | 06:25 PM
VenkmanP's Avatar
VenkmanP
Sweet!
Old Nov 3, 2005 | 06:30 PM
Zix's Avatar
Zix
Stock LT4 castings for the heads...but with about 4K worth of modifications and port work to them. They flow over 300CFM on the intake side and were ported specifically for the cam;
242/252 duration @.050 .55x/.56x lift on a 110 LSA
Still a hydrolic roller cam...the great thing is this car is just as easy to drive as it was when I just had heads/cam done to it. Very tame, until you hit the throttle!
I've got to get rid of my 4.10 gears, 1st and 2nd are pretty much useless unless you baby them and it just spins up too quickly to be useable. I'm thinking of going to a 3.73 rearend pretty soon.
Old Nov 3, 2005 | 06:54 PM
eherbst's Avatar
eherbst
that's really screaming, especially on a mustang dyno, great job.
Is that an all motor pass?
I would love to see a mod list too?
What size injectors/throttle body you running.
What comp. is it, and how much total timing is in it?
That should for sure run a new z06 off the road.
Old Nov 3, 2005 | 06:55 PM
MarkBychowski's Avatar
MarkBychowski
Very nice!!! Need details of the build!!!
Old Nov 3, 2005 | 07:05 PM
85vet's Avatar
85vet
Cruise-In V Veteran
D@mn,
That motor is a beast.
Old Nov 3, 2005 | 07:07 PM
mseven's Avatar
mseven
HOLY S**T , some pretty big numbers... congrats!!!
Old Nov 3, 2005 | 07:11 PM
Zix's Avatar
Zix
Compression is 11.3-11.5:1
42lb SVO injectors
TPIS 58mm billet TB
Timing right now in the upper RPM ranges at WOT is set at about 35*. It was initially set at 40* but we started getting some knock on the dyno. I called the guy who prted the heads and he wanted a max of 36* timing...we put in 35-36* and the knock was gone. And this is on crappy AZ 91 octane gas.
The owner of the dyno shop came through when we were making some runs and he was having a blast! The car sounds absolutely wicked running at 6900.
Mod list...well let me see;
All forged 383 LT4
Heavily ported LT4 heads and intake
Cam specs listed eariler
TPIS long tube headers (changed to EM headers soon I hope)
LTCC coil kit
Mez electric water pump
42 lb SVO injectors
58mm billet throttle body
Billet MAF ends
The short-block and heads were put together by Gary Grimes out in Georgia, he does a lot of powertrain development for GM and has one of he largest engine dyno shops in the country. He's not cheap, but he's one of the best. If you want any more specifics just let me know!
Old Nov 3, 2005 | 07:34 PM
zelement's Avatar
zelement
Got any clips of the car at idle with that cam?
I'll bet it sounds killer!
Old Nov 3, 2005 | 07:43 PM
jerkyboy's Avatar
jerkyboy
Those are fantastic numbers!! Congrats
Old Nov 3, 2005 | 07:51 PM
Zix's Avatar
Zix
I was actually thinking the same thing the other day! I really want to get some in-car and out-of-car clips...gimme a day or so and I'll get those put together!
Old Nov 3, 2005 | 07:57 PM
LT4BUD's Avatar
LT4BUD
Originally Posted by Zix
.......I've got to get rid of my 4.10 gears, 1st and 2nd are pretty much useless unless you baby them and it just spins up too quickly to be useable. ..........
Great numbers........
But with 7000rpm of capability why not think about tires that will hook??
If you are really spinning in 2nd gear, and I am sure you are, with that much power going to 3.73 isn't going to eliminate traction problems especially in 1st gear....then again you might need the 3.73's at the top end going thru the traps
Pleasant problem.......too much power....enjoy..
Old Nov 3, 2005 | 08:13 PM
tpi 421 vette's Avatar
tpi 421 vette
Nice numbers
To Back from the dyno---466RWHP
Old Nov 3, 2005 | 08:17 PM
Zix's Avatar
Zix
Until I really beef up the rear-end I don't want to put extremely sticky tires on there. I have a set of Kuhmo Victoracers available to me that I may test out a bit and see how that goes...
Old Nov 3, 2005 | 08:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Nice, very nice
Old Nov 3, 2005 | 08:35 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
Nice #'s!
