Fuel filter on backwards ( MAYBE )
Old Nov 6, 2005 | 08:23 AM
LT4-Z51's Avatar
LT4-Z51
Default Fuel filter on backwards ( MAYBE )
I noticed right after I had my fuel filter changed the car when it sat (over night ) took forever to start .I recently put a fuel press. gauge on & found out the pressure drops instantly from 42 to 0 when the car is turned off . Car use to start fine!!!!!Could the mechanic have put the filter on backwards & that be the problem?When he was changing the filter he was getting covered in fuel so I would say its a safe bet he wasn't paying attention..... 1996 LT4 !!
Old Nov 6, 2005 | 08:51 AM
bogus's Avatar
bogus
gee... I don't think the filter will do that... it may be flow dependant, but I don't think it acts as a check valve.
And smell of war fuel? I would wonder if the check valve in the pump hasn't quit.
Old Nov 6, 2005 | 09:12 AM
LT4-Z51's Avatar
LT4-Z51
I agree but I've read alot of threads on bad fuel pressure being linked to a bad filter, I just find it hard to believe that a fuel pump with 58,000 miles on it is bad!!!
Old Nov 6, 2005 | 09:18 AM
bogus's Avatar
bogus
58k miles... but it's nearly 10 years old.
Old Nov 6, 2005 | 09:29 AM
Muffin's Avatar
Muffin
Filter has nothing to do with holding fuel pressure.
Old Nov 6, 2005 | 01:00 PM
JeffM1243's Avatar
JeffM1243
I had the same problem with my '90 after the filter change......Turned out the filter outlet line fitting was half a turn loose and leaking. The car was hard to start and pressure would drop from 42 to 0 like a rocket when shutoff...Tightening the fitting solved the problem
Old Nov 6, 2005 | 01:11 PM
LT4-Z51's Avatar
LT4-Z51
Thanks for all the input checked the filter its on right ......
Old Nov 6, 2005 | 01:19 PM
vetster86's Avatar
vetster86
My 86 had only 29,000 on it when the fuel pump went.
Old age can do it.
To Fuel filter on backwards ( MAYBE )
