Can anyone tell me if there is a 3d model available somewhere of the LSx. I would prefer something in a Pro/E format, but any 3d modeling format would work.
I would like a copy also if anyone has anything like this that they would part with for nostalga's sake! That would be soo cool to have a printed 3d model (shhhhh don't tell anyone from work!)
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I haven't seen much of anything in ProE on here, but if it exists ... Probably would be something internal from GM in michigan. I wonder what software their designers use. Might still be pencil and paper.
I don't think you'll ever see anything like that in Pro-E however I've heard of things like 56 chevy's and stuff being done.
IT woudl take way too long... It woudl be need if you can add events to it.. for instance for a little project I built a small steam engine, modeled it in Pro-E then made it so it would run inside pro-e so you can watch valve timing and such..
I ended up making that thing on a small smithy and would you believe it turned 6600RPM @ 90psi?
