Code 43 revisited-89 A4
Old Nov 20, 2005 | 10:46 PM
cv67's Avatar
cv67
St. Jude Donor '05
Default Code 43 revisited-89 A4
Started a thread awhile back about a problem I had after changing the intake gaskets-Car would start and run for a few minutes then surge like crazy and die. Cause?
Distributor in a tooth off.
Even if you reset it exactly where you took it out, when the distributor is removed the oil pump shaft automatically moves a bit due to the cut on the gear, Aligned the shaft with a LONG screwdriver, moved it over one, timed it and voilla, runs like a champ. Now I just gotta hope my stripped plenum bolt doesnt cause a vacuum leak.
Old Nov 20, 2005 | 10:57 PM
kopbet89c4's Avatar
kopbet89c4
Code 43 made my Vette feel like a dog retarding timing to the base 6 degrees and no additional advance. Is that what is happening to yours now or is the SES light intermittent?
Old Nov 20, 2005 | 11:44 PM
cv67's Avatar
cv67
St. Jude Donor '05
Runs good now, 8 degrees timing, no codes or lights
To Code 43 revisited-89 A4
