Winter tires
What are you Folks running for winter tires? I live in the northeast Maryland area and will be driving our (new) '96 CE daily.
When it gets really bad (snow, slush), out comes the '61 Impala with the snow tires.
Thanks.
Regards.
and that newer "snow and ice" logo on the tire.Snow don't bother me, I think its fun, but studded tires are illegal here so they salt like f-ing nutz. turns all the cars into big ***** of rust.
»keith
Regards.
When the tire guy told me this, I was, "yeah, right...", but I ran only two on the rear drive wheels and the traction improvement over regular tires was insane. I could overpower the front tires easily on any slippery surface.
»keith
I only get snow a few days out of the year, so I don't see a need to have a special set of tires just for snow. So whatever I get will have to be year round.
"1986 CHEVY Suburban 4x4, mech. exc., ready to hunt, $2000"
The ads are full of these kinds of rough rides, and they can carry parts for your Vette in the other seasons.
Back to tire sizes: the 96 has 275/40-17 front and 315/35-17 rear. Looking at the Blizzaks for example, 245/45QR-17 is the tallest they have. This tire will be lower but not as wide as the factory. Is that correct?
Thanks.
As for the Goodyears I was going to buy some this fall. However, after reading the reviews I have decided to wait until after snow season is over before getting them. (The reviews say that they perform dismally in snow)
Mike
First # is section width(bulge to bulge)
Second # is the ratio of section width to height.
tire rack has a good explanation
I think that 245 will fit on the same rim your 275 was on, but 315's are a different story.
Generally, I prefer to have a separate rim and tire for winter. Although its been while since I've needed to do that since I've started driving suburbans for winter.
»keith
»keith
It's looking like that's the way to go. The max size for a Blizzak WS50 that seems right (I'm open to suggestions on this) is the 245/45QR17.
Keith,
What 'winter' wheels did you have?
Thanks.
Keith,
Thanks.
And I even won a couple trophies ice racing with those tires.
Previously, I had winter tires for my 1993 pontiac Formula, which had 245's from the factory on 16" rims and I believe I had arctic aplin's in that size, Q rated. I used the OEM rims for those, and I had my Firehawk 17" rims with Firestone Firehawk SZ-50's for summer use.
It seems 17" winter tires are tougher to find. I'm probably going to assume that 16" rims won't even fit on cars with the "heavy duty" brakes? that would open up alot of possibilities if 16" rims were an option.
If I needed vette snow tires, I would almost like to be able to use the stock rims, but that would probably be stretching it a bit with 245's on back. I just checked tire rack, and if I read the chart correct, they recommend a max rim of 9" wide for those blizzaks, and I think the stock rears like mine are 9.5" wide.
If you got two pairs of the 8.5" front rims, you could run that size on all fours and that would work fine in winter. I think I have seen those fronts for sale on some of the wheel web sites I've browsed.
I've been fortunate lately that I have been able to have separate "beater" vehicles for winter and because they are 4 wheel drive, I run an all terrain tire that works well all year round. BFG AT's to be exact, as of now.
That would be another option, if you had a bigger rim that snow tires do not come in, is look for a tire that has a good "wet" rating, and have it siped at a tire place with that capability, and you would probably have a 'descent' winter tire, although not as good as the new "snow and ice" tires. Even though "snow and ice" tires are best, a descent "summer" tire can do ok if it has enough sipes and tread voids to move the snow & water.
A question I never asked, do they allow studded tires in your state? Would you want studded tires?
HTH, »keith
i have GS-D3's for the summer, and the moment the temps dipped below 40 they hardened up and would spin at a stoplight start. they would probably be driveable all winter, but it is a pretty steep gamble to your personal safety.
good luck on the tire search, and have a fun winter!
