LT-1 Head for L-98
I ride bimota's so life is never easy.
Being different is one thing, but putting LT1 heads on an L98 is a total and complete waste of time.
Stick to proven heads that will provide the amount of power you need... and the thought of installing the L98 TPI on those heads is, sadly, a joke. It will buy you nothing but headaches and bragging rights, but your car will be no faster for all the effort.
If you want LT1 heads that bad, by all means, swap an LT1 in there and be done with it.
The TPI intake is a pig... it won't flow past 5000 RPM... just where the LT1 starts to wake up. I just don't feel it's worth the hassle, the cost, or the lack of pure performance. There is a reason these parts are not compatible.
If you want performance, check out Dart or AFR heads and a nice intake, such as the mini-ram or Super-Ram.
BTW, Bimota's are cool. I like Aprilia myself...
However, you seem to have missed the point of my post. That being, the heads on the L98 are NOT the restrictive factor - it's that pig of a TPI intake. Loose that and you are golden. New heads won't help one bit.
Allow me to give an example... you hook a 4" fire hose up to your house tap outside.... what is the restriction? Not the hose, but the lines leading up to it. That's what putting LT1 heads on an L98 is gonna do. NOTHING.
Now, if you wanna do something, there is the LT1 INTAKE conversion. That will put an LT1 intake on an L98. That will help a LOT.
As I stated, a super ram or mini ram will get you a ton of breathing.
Also, you can take that 4 hours and hone and port out the TPI. That will free up power. Edelbrock used to have a base and runner option, as does Arizona Speed and Marine. Check TPiS for more options.
I was looking for aftermarket heads, but saw problems there. Stated looking for 113 heads could not find them, the LT-1 heads became available, and told they would work with mods. I'am not a car guy do not calm to be, thats why there is 38,000 miles on this car in 21 years of ownership. Also would like it to look some what stock under hood. Do not claim this is a great mod, just some thing that would be like the ported 113.
from Chevy High Performance flow archieves at 0.400 in lift
http://chevyhiperformance.com/techarticles/41598/
stock 113 head 189 in / 157 ex
mild ported 113 212 in / 175 ex
LT1 head 213 in / 155 ex
Here's what I've settled in on for my 5500 rpm road racing heads
Edelbrock Preformer 216 in / 159 ex
It's a direct bolt on, flows slightly better than the LT-1 and has a smaller intake port volume so I should not give-up much torque. I'm also adding the LT1 intake.
If I was drag racing I might go with a bigger head but for road racing I'm thinking I still want some pull out of the low speed corners.
Dave Porter
89 Z51
