Dana 44
Old Nov 28, 2005 | 01:26 PM
93stroked's Avatar
93stroked
Default Dana 44
Hello Im installing a dana 44 diff. in my 93 (auto trans) can anyone tell me if I need to change the C-beam and driveshaft, I read somewhere that you have to change them with the ones from a manual transmission is this true? Thanks Mike
Old Nov 28, 2005 | 01:27 PM
vader86's Avatar
vader86
Read the Techtip, or look at my site for a link to it.
Old Nov 28, 2005 | 01:44 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
C-beam and drive shaft is shorter for the dana 44. You can shorten your auto driveshaft, and install the autos yoke, for the driveshaft, but may need to find a C-beam.
Old Nov 28, 2005 | 02:13 PM
CFI-EFI's Avatar
CFI-EFI
The drive shaft may work as is. Although the Dana 44 shaft is shorter, because of the "C" beam, there is very little movement in the slip yoke and the longer shaft has been known to work for some. The 36 "C" beam can be re-drilled and used with the 44 rear end. Don't forget speedo gears, if necessary, as long as it's apart.
RACE ON!!!
Old Nov 28, 2005 | 04:14 PM
Tom Piper's Avatar
Tom Piper
I've heard of others using the auto driveshaft.
But, on my '92 A4, I used a new 6 speed driveshaft with the front yoke from the automatic driveshaft and a new 6 speed C-beam.
Tom Piper
Old Nov 28, 2005 | 05:48 PM
93stroked's Avatar
93stroked
Thanks for all the info, this is the fastest Forum site ive been to trying to get some help Thanks agian
Old Nov 28, 2005 | 08:16 PM
Upstate's Avatar
Upstate
From: [Quote=WOEII] Is dried brown doodie powders man! [/Quote]
RACE ON!!!
hmmm. I wonder just how much shorter. I have a D44 in my auto equiped vette and despite what I've read on here regarding people being able to remove the driveshaft with the C Beam in place, I can't do it. I need to remove the beam and tilt the engine/trans down to remove the driveshaft. :scratcheshead:
My appologies for the threadjack
Old Nov 28, 2005 | 08:31 PM
okinawa86vette's Avatar
okinawa86vette
It's only about a 1/4" difference between the two driveshafts. The auto driveshaft will fit, but the extra length is enough you won't be able to remove the driveshaft without dropping the rear end.
Find a manual driveshaft and swap in the auto yoke.
Chris
Old Nov 28, 2005 | 08:50 PM
Upstate's Avatar
Upstate
The driveshaft is about a 1/4" or so from being able to come out. I thought I was prying on things way too hard and it went beyond my comfort level so I lowered the tranny.
Old Nov 28, 2005 | 09:34 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
the d36 c-beam is 1" longer than the d44 c-beam and the hole distance is 1 3/4" at each end. the d44 driveshaft is 26 3/4" from centerline to centerline of the u-joints. i don't have a d36 shaft to compare it to.
Old Nov 28, 2005 | 09:53 PM
highpockets's Avatar
highpockets
So where does a 88 c-beam and dr shaft fit in this pic ? length wise ? I am doing the same with my 95,is the 4+3 stuff different than the zf6 ?
Old Nov 29, 2005 | 12:53 AM
ASRoff's Avatar
ASRoff
I have a driveshaft and c-beam from my 94 for sale first $75 + shipping gets them both
Old Nov 29, 2005 | 06:24 AM
rodj's Avatar
rodj
THey are all the same , relating to the diff type only
D44 all manuals; same shaft and beam
D36 all autos : same shaft and beam
Old Nov 29, 2005 | 12:30 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Do yourself a favor and buy the appropriate driveshaft and C-Beam from that guy....it is soooo worth the $75...
To Dana 44
