Bilsteins
Old Nov 30, 2005 | 05:58 PM
bluealtered's Avatar
bluealtered
Default Bilsteins
Reading the pay it forward thread, i see that bilstein rebuilds their shocks, are all their shocks this way or only certain ones? my stock bilsteins (86 Z51) have 72,000 miles on them and it must be getting time to do some thing with them. What does it run to rebuild them, and after rebuilding and shipping is it cheaper to just replace them? ...joe
Old Nov 30, 2005 | 07:11 PM
tigmaned's Avatar
tigmaned
joe
i have only heard they charge to rebuild for what you could get all new ones for at soome places. my 86 had them but i didn't want to spend that much so i got KYB shocks for less then half the cost. but then again i don't have a Z51 suspension.
Old Nov 30, 2005 | 09:59 PM
Trog's Avatar
Trog
Call Biltsein... It was like $65 to rebuild one of mine, including replacing the piston rod. Still, not that expensive compared to a new shock...
I used KYB before I went to the coil overs & like them too. A bit harsh riding but quite cost effective at the time.
Old Dec 1, 2005 | 08:15 AM
bluealtered
Thanks guys, kyb's were my next question, i have them on my 4x4 and they work great, and yes i know it's apples and oranges. Bilsteins are around 250.00 and kyb's 150.00 the price differance isn't that bad , just need to know which will corner at high speed better and longest. thanks...joe
Old Dec 1, 2005 | 02:16 PM
GUSTO14's Avatar
GUSTO14
One thing no one has mentioned is that Bilstein will taylor the shock for your specific needs, not just rebuild it. It's something to consider if you think you might want something a little stiffer or milder than they were stock.
You might want to call them and ask about it before you make a decision.
Good luck... GUSTO
Old Dec 1, 2005 | 03:31 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Originally Posted by Trog
Call Biltsein... It was like $65 to rebuild one of mine, including replacing the piston rod. Still, not that expensive compared to a new shock....
Last time I checked, you could buy new Bilstein Sports for almost the same money. Not worth the trouble to rebuild, unless you want custom valving.
Larry
code5coupe
Old Dec 1, 2005 | 03:37 PM
Eike's Avatar
Eike
btw: Bilstein can rebuild your shocks to the characteristics you give them ... if you know what you want
Old Dec 1, 2005 | 03:50 PM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
To contact Bilstein for repairs
1-800-537-1085
Ask for Bill Hendorf or Jack French.
The address for shipping the shocks
Bilstein Repair Dept.
14102 Stowe Dr
Poway, CA 92064
Old Dec 1, 2005 | 03:59 PM
bluealtered
Thanks everybody, this helps alot. ...joe
Old Dec 1, 2005 | 09:46 PM
hippy's Avatar
hippy
I got a set of Bilsteins off my 90 that had 35000 on them when I pulled them off. Are they worth $75? They were fine yet, I just went to QA1s.
To Bilsteins
