Just curious if any will any GM 3 wire heated O2 sensor will work or are they per application only ?
Wide band is also on my mind. Who's got the best deal on wide band with readout and datalog software ?
I have the Zeitronix unit (not yet installed)
I have also the 3 wire heated Ac delco O2 sensor for closed loop operations. ( will check the part# ...there is an ACDelco unit that is the RIGHT one to use.)
The Heated one is on the driver side .
The bung for the WB Zeitronix sensor is on the pass side.
The zeitronix unit allow (but non in my plan) to use the WB sensor also as closed loop sensor (you do not need to use the stock or the heated sensor).
I paid around $280 with the software to se AF ratio on a laptop.
-Beppe-
