Quench - explained
Old Dec 3, 2005 | 09:06 AM
bogus's Avatar
bogus
Adding to C4 Tech FAQ. This is great stuff!!! Well done!!!
Now, a thought... modern engine designers are moving more and more of the combustion event into the cylinder head, in an attempt to reduce emissions blow-by. if I understand what they are doing, it essentially creates a seal at the piston to head area and really does weird things to the quench.
The downside to all of this is carbon buildup. I understand that the Northstar engine is very prone to this... as are some Mopar V6s.
Old Dec 3, 2005 | 12:29 PM
tjwong's Avatar
tjwong
So are the LS1 based engines.
Old Dec 3, 2005 | 12:55 PM
Pete K's Avatar
Pete K
I had quench explaned to me very simply. Minimizing quench maximizes squeese. The squeeze pushes the unburned air fuel out to be burned.
Your write up is excellent.
Old Dec 28, 2011 | 04:28 PM
kpforce1's Avatar
kpforce1
Checking up on the thread and discovered that the image links had changed.... I updated them accordingly.
Old Dec 28, 2011 | 04:57 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Well we FINALLY have a good resurrection!
I think it's great that you popped this old thread up to the top (and updated/corrected the links. I, too, agree that very few people understand quench, it's importance, and it's relevance. Even some of the so-called guru's didn't get it.
I recommend anyone building/rebuilding a motor take a closer look at this.
Good stuff!
Old Dec 28, 2011 | 06:25 PM
Caboboy's Avatar
Caboboy
Big time! I think quench and DCR are easily the two most overlooked details in designing a build and can make all the difference in the world.
Thx for bringing this back!
Old Dec 28, 2011 | 07:04 PM
1963SS's Avatar
1963SS
That was the clearest explanation that I've seen. Great job and thanks for the effort. That also explains why all dish pistons aren't created equal. Some are impossible to get a good quench like the one shown below. notice that the whole top is dished making it nearly impossible to get the distance required for a good quench
Now this style of dished piston has a very nice "Quench Pad" and will be able to squish the air from that area and into the combustion chamber.
The idea is to get the mixture in the combustion chamber as turbulent as possible before it's lit off by the spark. Here's a video that shows how rapidly the mixture enters the engine. It may be a little faster than you think.
http://youtu.be/UvmBLqjaZxY
Old Dec 29, 2011 | 02:51 PM
Crepitus's Avatar
Crepitus
Great thread! 1963 ss As you point out the piston shape is critical. To get 9.5 to 11 to 1 with a 64 cc head the best piston is the shape I affectionately call the D cup.
Old Dec 29, 2011 | 03:24 PM
1963SS's Avatar
1963SS
Although I can assure you that I'm a big fan of "D" cups I prefer to call this a "D Dished piston". But I do like D Cups a lot better. Sorry mods.
I use quite a few of the -16cc D Dished pistons on LT4's to get 11:1 compression. Mainly I'll use Mahle, JE/SRP or Diamond if I need to modify something. A lot of folks don't know it but Diamond will give you any dish volume you want for an additional 6 bucks a piston. It's no longer necessary to accept a compromise in quench, head gasket, combustion chamber or anything else. That may be one of the best deals on the planet. 6 dollars per change to get exactly what you need and want. Pretty cool.....huh?
Old Dec 29, 2011 | 08:31 PM
GREGGPENN's Avatar
GREGGPENN
I assume that's the same as inverted dome pistons. The idea is to squeeze perimeter fumes toward the center of the piston-head chamber...making them into a smaller ball.
Some sites liken inverted dome pistons to the most efficient burn design.
Old Dec 29, 2011 | 09:01 PM
leesvet's Avatar
leesvet
yep...its like the "other half" of the hemi (sphere)
Old Feb 19, 2012 | 11:53 PM
jesredvette's Avatar
jesredvette
Great info! Thanks for taking the time to do this, and for bumping it in front of us again. This is very helpful for us guys who are trying to figure out what to do to upgrade our engines and want to do it once and do it right.
Old Nov 17, 2012 | 09:57 AM
  #33
diehrd's Avatar
diehrd
This was an amazing write up that made simple a topic I was interested in understanding . And a very good read for anyone building a engine or its top end
Old Jul 25, 2013 | 10:12 AM
  #34
kpforce1's Avatar
kpforce1
Thanks for the kind words guys I will periodically check up on this to make sure that the images are still in place. Glad I could give something back to a community that has provided me with enough knowledge to be dangers. lol
