Acceptable LT1 compression?
Old Dec 4, 2005 | 01:06 PM
Fastmax32168's Avatar
Fastmax32168
Default Acceptable LT1 compression?
After reworking the heads in my LT1 and installing bigger valves I come up with about 53CC. When I calculate the compression with these and the thinner Impala head gaskets I already bought it jumps from stock 10.4 to about 11.2. I am using a lingenfelter cam that specs at 213/219 with zero overlap. My question is if it will run OK on pump gas with this compression ratio?
Thanks,
Roy
Old Dec 4, 2005 | 01:20 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
It should. In my current combo, I'm running 11.3 CR and have no problems w/ 93 octane premium. My new shortblock will have a tight quench area and about the same CR which will make it even less prone to detonation.
Old Dec 4, 2005 | 04:29 PM
FD2BLK's Avatar
FD2BLK
11.5 seems to be a popular pick with the LT1. Now keep in mind that the cam has a lot to do with what C/R you run. For keeping the knock down dynamic CR is more important then static.
Old Dec 4, 2005 | 04:53 PM
95NOSvette's Avatar
95NOSvette
...I know plenty over 12 to 1 running pump gas no prob, Just gotta have the right cam to pull it back a little, your current cam (even though it's on the mild side)should be alright with your new comp ratio
To Acceptable LT1 compression?
