valve setting guide
Old Dec 5, 2005 | 02:17 AM
steve1ph2's Avatar
steve1ph2
Default valve setting guide
just ran across this and wanted to share. http://www.centuryperformance.com/valveadjustment.asp. iv bought a set of roller rockers from another member and he pointed me to this web site. hope it helps.
Old Dec 5, 2005 | 07:54 AM
96lt4c4's Avatar
96lt4c4
Good info, I think everyone has there own way to adjust valves. But, I think I will try this out, the opposite intake valve way. Screw adjusting them while the car is running!!
Old Dec 5, 2005 | 08:27 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I used that method 2 years ago when i did my rollers. I never had to adjust them running or static again. There are lots of good methods and all are only as good as the person performing them.
Old Dec 5, 2005 | 08:51 AM
mseven's Avatar
mseven
Good link , that is very similar to the Comp Cams method .030 which on my set-up using an indicator came out to 3/4 turn. (c.c. also has theirs printed out in the cam catalogue).
Old Dec 5, 2005 | 04:43 PM
Muffin's Avatar
Muffin
OK, I will be quick to agree that the method will work. But what is wrong with bringing #1 to TDC and adjusting both intake and exhaust. Rotate the engine 1/4 turn and adjust #8, then #4 and so on. When #1 is at indicated TDC the cam followers should be at or near the center of the base circle insuring both valves are fully closed. 1/4 turn and #8 is fully closed. I guess it really doesn't make too much difference how just so long as you get the job done right.
To valve setting guide
