Who makes the best gasket remover. I am starting to put my car back together and thought it was all downhill from here. Was I wrong, I am removing the old timing cover gasket material and am having a beeatch of a time, any recommendations ????
Permatex makes a spray on gasket remover that works very well. Just spray it on, wait a few minutes, scrape off the goo, if theres more then repeat the process. And it don't even smell that bad
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Don't get it on your skin though. It's also one hell of a paint remover, be careful where you spray it.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yeah, the snotty napalm type stuff in the spray can is good stuff. And as long as you're working on steel, chisel away. You might even use a brass wire wheel on an angle grinder or something. I only use a razor blade or a very sharp chisel on aluminum.
Yeah, the snotty napalm type stuff in the spray can is good stuff. And as long as you're working on steel, chisel away. I only use a razor blade or a very sharp chisel on aluminum.
Yep....you can gouge it very easily. The key to using the gasket remover is letting it sit long enough. I always go over the gasket surface with a good degreaser and then wipe it clean before applying the new gasket. Never had a leak yet.
I agree, I used a degreaser to loosen the material then a sharp raxor knife to clean the block.
