Power steering leak
Old Dec 8, 2005 | 01:45 AM
BIG K's Avatar
BIG K
Default Power steering leak
I am still trying to run down a leak. I replaced the power steering pump as it looked like the leak was coming from there. I am still leaking power steering fluid.
Is the only thing left that could be leaking is the 2 hoses and the fluid tank?
If I replaced them, shouldn't this stop the leak or is there something else that I should be looking at?
Thanks!
Old Dec 8, 2005 | 09:47 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I would clean the area spotless then check for leaks while it's running. On ramps would be best so you can get a good look. My system was leaking at the pinion valve on the rack. Did you replace the "O" rings when you did the pump
Old Dec 8, 2005 | 06:33 PM
BIG K's Avatar
BIG K
Default Power Steering leak
Yes the O rings were replaced. I had the car up on a ramp, and I remove one of the braces to see better. I couldn't see anything leaking.
So, what and where is the pinion valve?
Old Dec 8, 2005 | 07:37 PM
AGENT 86's Avatar
AGENT 86
The pinion valve is located where the steering shaft enters the rack
Old Dec 8, 2005 | 08:20 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Most of the PS leaks are caused by the hoses they don't last forever.
Old Dec 9, 2005 | 07:29 AM
Topload's Avatar
Topload
I chased a high pressure hose crack that I just couldn't see with the naked eye for a couple of weeks - finally gave up and replaced it with the DRM stainless steel line - problem solved. Now if we're talking about the PS groan on a cold engine....that's another story.
Old Dec 9, 2005 | 08:32 AM
Brimis's Avatar
Brimis
I had a power steering leak and it turned out being the hose, but I my case it was not tight. If I recall correctly, its pretty tight under the car. I had to position myself at the right angle in order to tighten the hose.
I'm sure you can clean the area good and then search for the leak.
Good luck.
Old Dec 10, 2005 | 10:49 AM
BIG K's Avatar
BIG K
I sure hope you are right. It would be easier(I think to replace the hoses instead of the rack).
Thanks!
To Power steering leak
