headlight assembly
Old Dec 11, 2005 | 11:12 PM
jarrettjp's Avatar
jarrettjp
Default headlight assembly
hi! when i open the headlights the left one opens halfway,or points to the ground.the other one works fine.they will both close after a few off and ons.could the problem be electrical? thanks----john
Old Dec 12, 2005 | 12:40 AM
newbecorvetteguy's Avatar
newbecorvetteguy
I won't know the answer to your question, but you have to say what year your car is for someone to be able to help. There's more than one headlight setup.
Old Dec 12, 2005 | 01:09 AM
sami85L98's Avatar
sami85L98
84-88 uses 3 wire system and 88-96 is a two wire and better system. To me it looks like headlight motor is bad, just bought an headlight passenger side motor from ebay for 100 bucks with core return worked perfect, mine is a 85 3 wire. Replacing headlight motor is easy u can do urself 1/2 hr job. Check ebay.
Old Dec 17, 2005 | 11:46 PM
jarrettjp's Avatar
jarrettjp
Default jarrett
sorry about that--my vette is a 1990 coupe. ---thanks,john
Old Feb 17, 2006 | 10:17 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
That being the case, it sounds like your bushings have gone bad. Click the article link below for installation instructions.
You can purchase the bushings from Home Depot or from Eckler's, MAM, and the other Corvette specialty catalogs.
http://corvettefever.com/howto/33098/
To headlight assembly
