Plastic screw retainers
Old Dec 17, 2005 | 05:06 PM
DougSilver's Avatar
DougSilver
Default Plastic screw retainers
Some of the screws for various parts screw into a plastic fitting--for example the screws that secure the headlight bezel. Are these things replaceable and, if so, where do you get (from the dealer?). The specific reason I ask is that the screws that hold my headlight bezel on are not tightening very much and I suspect the plastic gets shot quickly. Any other recommendations?
Thanks.
Old Dec 17, 2005 | 05:14 PM
Jerris's Avatar
Jerris
Default Try NAPA
I was able to get these plastic inserts from the local NAPA store
Jerris
Old Dec 17, 2005 | 06:39 PM
kize's Avatar
kize
I purchased mine from a local auto paint supply shop. They have a hardware/clip area. You can buy a whole box for what it costs for 5 at a car parts shop. I have found just about every plastic clip and hardware item there. And I keep going back - every plastic part I touch breaks or crumbles.
Old Dec 17, 2005 | 06:48 PM
DougSilver's Avatar
DougSilver
I've seen auto shops that have boxes of miscellaneous clips, screws, grommets, etc. but I figured the odds of having exactly the right ones were slim. It seems that they always have something that is almost what you need but not exactly.
Old Dec 18, 2005 | 12:23 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Thanks.
If youre talking them white square pieces,most dealers carry them.If not then the autobody store always has something you can use.
To Plastic screw retainers
